Have a question? Ask Woody!
help needed
help needed
help needed
roninkokomo
>I am making a small arts and crafts style bookcase. I have six 1.5 inch square posts that I need to cut those little pyramids on top. The directions say to use the table saw with the blade tilted to 15 degrees. I'd like to use hand tools to do this and have top notch hand saws Independence Tool serial # 125 ( drive by gloat)
I do not think my Langdon miter box has a stop at 15 degrees??
any suggestions? Thanks
Re: help needed
arbitrary mitres *LINK*
paul womack
>A sloping false table, either on the table or rear fence should do it. Cut nearly to length, then cut the slope.
My mitre saw can cut at any angle (a modern Nobex) but isn't compound.
When I needed a 4.5 degree cut in both dimensions, I set the saw to 4.5 degrees, cut a table (a simple slice from a 2x4), then used the table under the workpieces. This gave a perfect compound cut.
BugBear
woodnet thread
Re: help needed
Link
roninkokomo
>The link got me to a discussion of the new WoodRiver Planes?
Re: help needed
May not have a stop
>but if it's like mine, you can set the saw anywhere in its range and lock it down (methods vary, I believe - on mine, it's a lever underneath). On my box, I can set infinite angles, subject only to my holding my mouth right; I've even been able to set an angle a degree or less off one of the stops, even though the saw really really wants to slip into the stop, just by asserting myself as the alpha dog, holding things in place while I tighten the lever underneath.
I don't know if later or other models were less effective this way, and, if they were not, then this message won't help much.
If you have a sliding bevel, you can set it to your desired angle and then hold it against the back of the miter box and the saw. If you're doing a lot of them, I suppose it might make sense to make a gauge block - 1x pine cut to the angle or something - so as not to accidentally lose the angle when the sliding bevel shifts. This would also be the approach if you don't own a sliding bevel (of course, if you don't, this is a GREAT item to put on the present list - even the Cadillacs like the Lee Valley bevel aren't too expensive, and the uses of them are endless); lay out the line (see your geometry texts for laying out a particular angle), cut and plane to fit, and there you are.
Re: help needed
Shooting board
Alex Yeilding
>If I read your question right, you are looking for a hand-tool method.
Add a spacer to your shooting board fence to get a 1:4 slope (or do the trig if you care about hitting 15 degrees exactly). Scribe a target line for the bevel, and cut to length about 1/4" beyond this line. Then plane to the line. On the first two sides, stop slightly short of the line, since the opposite side is bearing on the fence not at the corner of the bevel, but at the rough-cut length. Then finish planing to the scribe line once the opposite side is beveled.
Re: help needed
Thanks Bill
roninkokomo
>I got a bunch of sliding bevels. I may have gotten to your suggested method eventually, but I am rusty so it would have taken a while. :)
I am not sure if the miter box will lock at 15 but I will give it a go as that would be the surest route.
Thanks.
Re: help needed
Looks like fun
roninkokomo
>I'll try that too!
Re: help needed
browser trouble
paul womack
>my browser remembers stuff from my previous posts :-(
BugBear
Re: help needed
Uhhhhh freehand?
Scott Burr in Ben Lomond, CA
>Just lay it out and cut with a good saw clean up with a low angle plane.
Or am I missing something here...
Re: help needed
Re: Uhhhhh freehand?
>I think one of the things about those little pyramids on the A&C furniture is their consistency. Not impossible freehand, but if it can effectively be set up with a jig - like, say, a good miter box - no reason why not.
Re: help needed
Re: help needed
Manny
>You mean something like this?
Re: help needed
Step 1
Manny
>Mark the height of your pyramid around all four sides.
Re: help needed
Re: Step 2
Manny
>Draw diagonals from corner to corner in each rectangle formed by the end and the pyramid baseline on all four sides. You're going to make four cuts. Each cut will be along the diagonal and down the adjacent pyramid baseline such that the kerf connects the corner of the post to the point of the diagonal, on the adjacent side, that touches the pyramid baseline on that adjacent side. Sorry but that's the best I could do to put it into words. The pictures in the following steps will help.
Re: help needed
Re: Step 3
Manny
>Here is the start of the cut. The cut is at an angle along those lines. The cut starts at the post corner and you angle the saw down towards you. Make sure the teeth do not cut past that post corner.
Re: help needed
Re: Step 4
Manny
>See how I'm keeping the furthest part of the saw on that corner and dropping the handle down to cut along that adjacent baseline.
Obviously this is a Japanese saw. You'll have to adjust for a western saw. The basic concept is the same.
Remember you have to make this cut four times - once on each side.
Notice how I forget to move the lumber to the edge and saw into my bench. Don't do that. :-)
Re: help needed
Re: Step 4a
Manny
>This is your final position for the cut.
Now rotate the post 90 degrees and do it again. Total of four times.
Re: help needed
Re: Step 5 - the finale
Manny
>After the fourth cut the end will fall off. If not then put the saw back in each kerf and make sure it goes from corner to corner.
The excess on the ridges can be cleaned up with a sharp chisel. Just lay it against each facet and make a shear cut. It takes practice to get all the ridges to intersect at the tip and each corner. It's been a while since I've done this so you can see it's a bit sloppy.
Re: help needed
Allow me to point out...
James Watriss
>If you have a miter box, and there's not a perfect stop at 15 degrees, I say clamp the fence in place at something close, and go from there.
The key to any of those little pyramid things is consistency, and there's nothing specific to 15 degrees that makes it special. Take a scrap, cut it to find an angle you like, clamp the fence in place and go with it. As long as you can hold that particular setting though all 16 cuts, it doesn't have to be EXACTLY 15 degrees. The real key to that consistency, of course, is a stop to hold the other end of the leg. Otherwise you get a point that isn't perfectly centered.
Re: help needed
Thanks Guys
roninkokomo
>I think the Miter box method is best for me
I am a little rusty with my sawing technique and it will be the safest after I jig it up.
Re: help needed
Greg B�tit, Vergennes VT
>That was really slick!
Re: help needed
That is so well done, Manny, a great lesson.
Pam Niedermayer, Austin, TX
Re: help needed
Larry Barrett
>What a clever way to do this. Your explanation was perfect. I just tried it, with success. Thanks.
Re: help needed
Charles
>You 'da freaking man. Very cool.
Re: help needed
Uhhhhh Bill,
>I do them all the time. Nuthin' a sharp chisel and a well tuned block plane can handle. Yes, the plane is secured in a vise and I pass the pin over it...
Re: help needed
Well done Manny!
>Perfect example. Nicely shown too!
