PPI for Stair Saw
PPI for Stair Saw
PPI for Stair Saw
Patrick Gibbons, Katy, TX
>Mr. Shepherd got me to thinking about making a stair saw, seeing as how I haven't made that useless tool yet. When I used a tenon saw for the purpose of cutting out a dado last week, I found the 11ppi clogged up quickly. I wonder what the optimal ppi and tooth shape is for this purpose? Atkins, in their 1919 catalog, lists their flooring saw as being straight gound with the teeth bevel filed. What is bevel filed? Their stair saw comes in 6", 8" and 10" but no mention of tooth count. Disston, in 1919, offered a 6" stair saw of 20 gauge steel with 8ppi. No mention of tooth shape but the picture of the saw seemed to have teeth similar to the patternmakers saw which I know was neither filed rip nor crosscut. Simonds' 1910 catalog does not list one and neither does the 1915 Spear and Jackson catalog.
Re: PPI for Stair Saw
Marv....... Northern California Lake Co.
>Hi Patrick,
Disston made one with 8 points per inch. Beveled means the teeth are filed crosscut.
11PPI will load up easily because of the way a stair saw is used with short strokes, unlike a regular saw that pushes the sawdust out the bottom of the kerf.
I would go with 8 or 9 PPI.
Marv
Rip or crosscut?
Scott Burr in Ben Lomond, CA
>You NEED both kinds ya know!?!
Re: Rip or crosscut?
Pedder
>really? Aren't stairsaws build to cut sliding dovetails? IMHO sliding dovetails along the grain don't make sense. Because of that you only need a crosscut stairsaw.
Cheers Pedder
Are you sure bevel filed means xcut?
Re: Are you sure bevel filed means xcut?
>Patrick,
When filing handsaws, the word "bevel" refers to the angle that is used to make a tooth a crosscut tooth. The word "fleam" is also used when referring to the bevel angle. A stair saw cuts cross grain, not with the grain, even though you are sawing at an angle.
A rip tooth has zero fleam/bevel angle, however some people will use a few degrees of fleam on rip teeth to give the teeth a little more bite, but it's still a rip tooth. Rip teeth should look like little chisels while crosscut teeth should look like shark's teeth.
Saws such as keyhole saws and compass saws are filed somewhere in between a crosscut and a rip because they cut both with the grain and across the grain when sawing a circle or curve. Because of this half and half feature, a keyhole saw is an evil cutting saw. When I file a keyhole saw, I use more bevel so the teeth are in fact crosscut. A crosscut tooth will rip pretty well, but a rip tooth doesn't crosscut worth a damn.
Also, a stair saw should have slots in the blade so it can be adjusted up and down so you can control the depth of cut.
If you are making a tool that you don't intend to actually use, it really doesn't matter how the teeth are filed?
Marv
Disston Stair Saw
Kenneth Martin Sacramento
>I have a Disston stair saw I picked up some time ago. The blade is 6 in, 8 point and is filed crosscut.
Jim Crammond in Monroe, Mi
>Patrick,
I agree that the PPI should be fairly coarse, 7 or 8, to help remove sawdust from the kerf. In my experience, there should also be sufficient set to keep it from binding in the kerf. I use mine for dados and sliding dovetails, so it is filed cross cut.
Also, I'm not sure if it is from the two handed grip causing extra down pressure, but I think that you should file a stair saw with the least aggressive rake possible, 30 degrees. This filing is called peg tooth and it also cuts on the pull stroke. Using a stair saw is kind of like scrub planing, it is quite a work out.
Jim
OK here we go...
>When making stairs there a few ways to go about it. Look into stair making and you'll see what I mean.
PLEASE NOTE: I KNOW OR NOTHING ABOUT TERMINOLOGY OR MAGIC PHASES OF STAIRS. just built a few...
The crosscut one will make the crosscut for the step's to fit on the frame (runners?) The rip one will cut the long dados in the step that the thiniges that hold the front of the step up, and to the back of the one below it stairs to keep you from looking through them (also support). Rip and crosscut your butt of until you reach the top.
Hope this make since.
ok
Pedder
>thought plow planes were build to do that job, but than what do I know.
I never build a stair. (But a stair saw wich is handy for sliding dovetails.)
Cheers Pedder
>Marv, if you look at my original post, I mentioned that the floor saw was bevel filed. I mentioned it because of its use to cut out flooring which has a similar capacity to what I'm looking for (a tool to use with a router plane to cut out dados). The catalog made a distinction between xcut and bevel filed, or so it seemed to me. BTW, I am familiar with bevel and fleam and have sharpened some saws myself. I also do intend to use the tool if I make it. I'm not sure why you doubt that.
>Hi Patrick,
I took that to mean that you were inspired to make a useless tool.
Then you asked about what "bevel filed" means, so not knowing your level of experience filing saws, hence my blab about that.
Happens to me all the time...everytime I think I need to explain something to someone, I soon learn that they usually know more than I do. LOL
I would explain "straight ground and bevel filed" but.......
Marv
>I'm just too testy lately. I need to go to a corner until I'm happy again. Sorry about the bad attitude.
Greg B�tit, Crown Point, NY.
>Reminds me of the time I tried to explain to Larry Williams about wooden planes. I forget who clued me in, but talk about a "duh" moment...
greg
Well a plow can go both ways too...
>So why do we need stair saws?
Salaman says.....
Wiley Horne--So. Calif.
>R. A. Salaman, "Dictionary of Woodworking Tools", p. 432.......
"Sometimes made adjustable for depth of cut.....Used with or without a fence to cut the sides of grooves across or at an angle with the grain, e.g., in staircase strings."
Sounds to me like the original purpose was to outline the tread and riser housings in closed staircase stringers. But you would still have to remove the waste to complete the housing, right? Would work the same for any other stopped dado. Could also see this being used to cut a damaged tread out of a double-housed staircase, for replacement. Or to cut out a damaged piece of floor for replacement.....whatevah
Wiley.....just making this stuff up (except for Salaman quotes).
sliding dovetails
Pedder in nothern Germany
>Hi Scott,
I can't make a sliding dovetail with a plow plane. This is why I "need" a crosscut stairsaw (and a router plane).
Making sliding dovetails along the grain doesn't make sense to me. A dovetailed groove wouldn't hold better than a square one. A square one is made faster by a plow plane. This is why I don't "need" a ripcut stairsaw.
Cheers
Pedder
Just trying to make a point. Yours
>Is taken to heart as well. Sorry I forgot we're talkin' sliding DT's.
MikeW
>The coarsness of a stair saw's toothing, like any saw, depends on the woods it will be used on. Same with the length of the saw--if one consistently is making cuts in 12" to 24" material, make two of the buggers (one longer than the other).
A stair saw as one will find vintage was made for just that--cutting the housings in risers. These are relatively short cuts in soft white woods. One can get away with 7/8/9 ppi rather well. And, in some of the furniture making woods an 8/9 will work. But try that coarse in harder woods and it is more frustrating than it ought to be.
The good news about making a stair saw is other blades that are toothed differently don't require a new body to house them.
With a finer toothed stair saw, if the kerf is clogging on a stopped or blind cut, just blow the thing out or insert the saw from the blind end and drag back to the open end. Even so, if the set is a little wider than "normal," the waste out to climb the saw plate for as shallow a cut as is required.
Take care, Mike
