Cushions for Morris Chair
roninkokomo
>I am thinking of doing a Morris chair and ottoman,
Is there a place that I can get the cushions that I need?
Re: Cushions for Morris Chair
ThomD
>There are lots of places that sell the fabric and do furniture recovering. We have a local place that has CNC cloth cutters and a bunch of people sweating over Jukis. You can do everything from have a custom recovering done to buy the parts and make it yourself. That would be the standard route. These days there must be some online thing that does it also.
Norm did some upholstery projects a few years back, and I thought he did a pretty good job keeping it simple, yet "classy" as they say in trailer parks. His plans and video came with a supplier in the NC furniture trade that would send out the parts for you to do your own covering. The process was really simple. It was leather, and the basic drill was to nail in the strapping in the frame; build up the layers of foam and batting; then pull the leather over the top, as easy as making a bed, and secure it to the underside of the frame with staples; then a trim and cute nails was put around the base to trim it, and a cover was attached to the bottom to hide any sign of the nailing. A quick job with a durable result.
Jerry Gibbs
>I brought mine in to a local upholstery shop. I mean the actual chair so there was no question about the measurements. I ended up getting foam covered by vinyl. Leather sounds good until you price it. I would definately go local for the custom fit. It also gives you a chance to test foam firmness. Jerry Gibbs
Mike Fitterling
>"Leather sounds good until you price it"
True. I still opted for leather, but those cushions cost me over $800 when I made my Morris Chair. It will take an entire hide, and the foam is not cheap either. I had someone local make mine, but the big expense was the materials; labor was not much at all.
ouch!!!
roninkokomo
>800 bucks????
Re: ouch!!!
Patrick Wheatley
>Ouch is right.
I made two chairs at the same time and when I got quotes for the cushions it cost me almost 1000$ for 4 cushions and that was for fabric covering! I told my wife that if I had known the cost of the upholstery I would have made something else. Although now that they are in the sun room I am very happy with them and the cost of the cushions seems worth it now (but never again!).
Find ready-made cushions first (cheaper),
Chuck Nickerson
>then size the chairs to fit. Savings could be 50%+
Thanks
roninkokomo
>I really want to do this with hand tools,( although there may be a daunting number of mortises to chop) but it sounds like there are some plans online that I can get and it sounds like they describe making the cushions. at $800 bucks to buy them, I think I'll suck it up and make my own.
Ron
OK any suggestions
roninkokomo
>Where would you look.
My internet search did not turn up any options
Inexpensive hides for box cushions & other stuff *LINK*
David Barnett - SW Florida
>eBay has several sellers that offer 50 sq ft or larger upholstery hides suitable for Morris box cushions. For example, a 53 sq ft ivory hide goes for 139.00 (Buy it Now price). Look for hides that will yield about 5 square yards.
It's best to make a paper pattern so you'll know what you're looking for. Library books and online sources can show you how to sew a simple box cushion. It's pretty easy. Most of these leathers can be stitched on regular sewing machines, but hand stitching is completely fine. Just keep your stitches evenly tensioned as you go. Start with the less-seen seams first, but it won't hurt to stitch a practive seam or two with scrap edges. You'll want 'firm' foam, and yes, the good stuff's not cheap. Online sources will often cut it to size for you but check for squareness and accuracy. This can vary depending on the supplier.
I can't see well enough to find YouTube video tutorials, but you can give it shot.
Hope this helps.
Kyson Leather
Re: Cushions for Morris Chair *LINK*
Tom MacGregor
>I Googled "chair cushion" and a bunch of places came up. I haven't dealt with any of them but I ran a trial custom 4" set of top & bottom cushions that totaled $129.00. Might be a place to start...
http://www.cushion.com/
Jerry Gibbs
>I noticed you are thinking of doing the Morris chair. If you do not have a lot of experience with M&T work, start with the ottoman- less wood to mess up. I think it is ok to cheat and not do through tenons. Jusk put a fake one on the other side. It is easier and the through tenon is not needed for strength. The entire chair and ottoman is a lot of and work. the solid wood is also expensive. the cushions are no place to cheap out. I guarantee your attitude toward the cushions once you see your hard earned chair and ottoman. Jerry Gibbs.
Thank You
roninkokom
>For whatever reason they did not come up in my search
Thanks
Thanks Jerry
roninkokom
>My woodworking skill level allows for the project. Have dome lots of M and T joints, even quite a few by hand. There are a bunch of em in tis project.
Ron
Thanx
roninkokom
