Not quite fine woodwork, but fine wood.
>Jarrah flooring in the office I am building above the workshop/garage at home. All tongue and grooved and 19mm thick. Took an entire weekend to do with the help of a friend.
That shot is looking through from the waiting room, past the entrance on the left, to my consulting room. The end window frames the top of a Jacaranda.
Skirting still to go on.
Below is a part of the waiting room - this room could be converted into a kitchen, hence the pipes sticking out the floor and wall.
I needed a way to hide these, so I built a bookcase. This will house magazines and children's books. Jarrah top and Pine carcase.
It's a sort-of-Shaker-Derek design.
Re: Not quite fine woodwork, but fine wood.
Hank Knight
>That's really nice looking, Derek. It should last a long time.
BTW, I envy your balmy weather (open windows, green leaves, etc.). It's really cold here.
Hank
ThomD
>Is that one of those deals where you dovetailed the top, and biscuit jointed the bottom. I've done that, felt dirty, but... Or did you do a sliding dovetail? I once did a bookcase like that where I took the high road and put the tails on the top to brace the loads of the shelves, but I biscuited the framing shelf. Actually, all five shelves were biscuited, so pretty much zero chance of it coming apart. Supprised I got it together!
Alex Grigoriev
>1. I see you didn't feel like getting rid of roller marks on your pine boards :)
2. I wonder if I make pins on the sides, and half-blind tails on the top, would it make more sense? Can half-blind DT be made that way?
>Hi Thom
No biscuits. The lower shelf is inserted into a dado, glued and toe-nailed (from the underside). The centre shelf is adjustable over two heights (the rests are set into mortices so that they cannot move).
design
paul womack
>Nice floorboards!
Whilst I admire the skill in cutting those DT joints, I find such a small number of very narrow pins dis-proportionate; I'd have preferred a more Arts and Crafts approach. The whole "evident integrity" thing.
I have no doubt, since the load on the joint is rather low, that your joints will be strong enough though.
BugBear
Re: design
>Hi BB
The other furnishings are a little too modern for Arts and Craft. Ash and a soft tan wool upholstry.
The choice of dovetails started off an attempt to make the piece look "light", that is, create a sense of delicacy. I must say that I think this works and it does look better in the flesh. Chopping into this Jarrah was really hard work.
The construction is very strong - a little overengineered if anything, as I have visions of hyperactive young children climbing on everything - and there is strength also due to the glue.
What no WC?
Scott Burr in Ben Lomond, CA
>No not wood central...
Derek, looks fantastic. Seeing what I pay for a piece of jungle wood like that. Guess the economic times haven't hit ya.
Noe why would you put such a great piece of wood on a POS pine frame!?!
SWEET!
