Fireplace surround project pictures...
John Aniano in central NJ...
>Hello All,
About 3 years ago, I finished a fireplace surround to make our Rumford fireplace look like one my wife and I saw in Williamsburg. I thought I'd finally post the in-progress pictures I took during the project.
This is the original Powell House fireplace we decided I should try to recreate:
When the mason was done making a mess in our living room, this is the "canvas" I had to work with:
Actually, our mason, was great in every way. He did a wonderful job!
By the time the picture above was taken, I had already made the bottom moldings that surrounded the brick opening. I needed to finish this in order to get the final OK on the building permit.
All the moldings were run using antique molding planes, some English, some American. The material I used was pine from Home Depot, etc., nothing special other than selecting nice straight boards. The pegged joints in this picture are half-lap and plain miter. Pegged through mortise and tenon joints were used in the raised panel portions at the top and sides, shown in other images below.
The raised panels were cut with an English plane:
All rebates were cut with a moving fillester plane. A few electrons were used to rip stock on the bandsaw...
The mantel was constructed in layers, the most difficult being the dentil molding "teeth". I chose to mark them out with a scribe and cut each one with a hand saw using a clamped-on depth stop. I began the cut in the center of the saw blade and finished where the "stop" was clamped so each kerf was identical in depth.
After being sawn, I removed the waste with a Stanley router plane. I had to make a custom width cutter - the one that came with the plane was too wide.
When ready, the layers of the mantel were assembled in place using screws and cut nails.
Two coats of an oil-based paint finished the job, note the proper painting attire!
The final job:
Debbie and I enjoy using the fireplace often. The Rumford design can throw out a lot of heat, but does consume wood quickly. At some point the rest of the woodwork in the living room will be painted the same blue color.
John
Re: Fireplace surround project pictures...
Warren in Lancaster, PA
>Looks good, John. Where did you get that great pair of hands?
Wiley Horne--So. Calif.
>Beautiful, John!
Looks so traditional and just right! You could have done way more bragging about the complex mouldings that you made--they're as crisp as they can be. Very striking.
Thanks very much for sharing.
Wiley
allenmorgan
>Beautiful work. I like the way you hid the dentil molding. Color looks good too. I'm confused tho, what's the panels on the right? Do the hide a storage area?
John Aniano in NJ...
>Allen,
No, the panels on the right hide nothing but a mistake. The fireplace was supposed to be centered between the two windows on the long wall of the living room. However, when opened up from the outside, we found a main support beam there, so the firebox was moved to the left about a foot, hence the added panels to the right. The chimney was also widened to accommodate the shifted location. I WISH there could be storage there, but no...
John
>Warren,
I guess my father and mother are to blame...
John
Hank Knight
>Very nice, John. I, too, love the traditional look, and it's especially nice done with hand tools. Beautiful work.
Hank
Real Purdy, John.
Ron Bauman
Pam Niedermayer, Austin, TX
>Gorgeous work, John, as usual; but it's nice to see your small wood skills translate into large so nicely.
Tell me about your Rumford. Why did you build a square brick arch instead of round? Interesting that it eats wood so quickly. Does it prefer any specific species? Jack and I were about to build one in our Cape house when we decided to move to Texas instead. I have a spot all picked out for the Count here. :)
Pam
wilbur
>Very nice job, John!
One question: in your picture where you're using a router plane to get rid of the waste between the saw cuts, it looks like you're levering out the waste with the router plane. Was that how you used the router plane? I would have probably used a chisel for the bulk waste removal, then use a router plane to clean up the bottom, which is of course less efficient and uses more tools.
Don't you just love moderen planning....
Scott Burr in Ben Lomond, CA
>in Architecture. What ever happened about thinking of these things and actually planning around something as big as fireplace. After all it probably the only heat source in a house besides the kitchen stove.
Anyway, You did a fantastic job there.
Jim Shaver - Oakville, Ont
>Beautiful Work John!
I enjoyed my visit to your home many years ago...I can feel the ambiance of that room and it's warmth now.
Take care,
Jim
>Pam,
The Rumford fireplace uses the standard precast upper parts, I think its called a "brest" or smoke shelf (?). This sort of mandated a flat topped opening - I'd guess that some sort of custom smoke shelf would have been needed to do a curved top.
As for wood species, we've used red oak, black and honey locust and some ash - the best is the oak and locust. We had a large sycamore tree come down and that specie sort of just "melts" in the firebox. Yes, there are flames, but not anywhere like the oak or locust. Black walnut (I know, sacrilege!) burns well as does common chokecherry, all woods we get sort of for free. A neighbor has a wood lot and once a year we do a communal log splitting and stacking day so what ever specie he has is what we burn.
The logs burn quickly if on end, in sort of a tepee arrangement against the back wall - this throws off the most heat. A slower fire results if the logs are on the two grate/supports in the usual "yule log" pile.
Hope this helps,
John
>Wilbur,
I didn't picture the actual method I used to snap out the waste - a card scraper wedged in the kerfs and rocked. There was so little end grain attachment that the waste just tended to snap out. The router plane just leveled out the bottom of the grooves. The image I posted was sort of misleading, sorry.
John
