Squaring a corner with hand planes is easy - pics!
wilbur
>I have two more glue joints to go before I'm done with the top of my workbench. Should be done by the end of the weekend. I'm just doing one glue joint a day.
Some of my local friends look at me like I've grown a second head when I tell them what I'm up to, especially when I tell them that I'm doing this with hand planes. This is probably not new to most of the folks here, but I thought I'd share how this is really not as much manual labor as you might think.
Here's a picture of how out of square the beam I was working on this morning was.
That's out 1/16" over the 3 1/2" width of the beam. Boy do I suck!
Now, when most people think of hand planes, the image of a finely tuned plane making those 0.001", wispy, see-through shavings that just float in the air immediately comes to mind for most people. We don't need no girly-man plane like that for this job. :@)
I have a jack plane set up with a decent amount of camber and set for an aggressive shaving. This is the shaving that I get with this plane.
Just under 1/100" thick, and it falls straight to the ground. Japanese plane aficionados like myself would be horrified at such a thing. :@) But this is important for this purpose.
Remember, I need to knock down 1/16" to get the faces square. 1/16" = 0.0625". If my plane takes a shaving 0.009" thick, it should take me only 7 swipes of the plane to take off 1/16" of material.
This is what I got after 9 swipes. (I got excited.)
Not too bad! And easier than trying to put an eight foot long 4x4 back on my jointer. Not to mention the lack of dust and noise. :@)
My beam is eight feet long, as I said. I can work on a 2 foot section at a time, so 4 rounds of this and I have the whole beam squared up.
Re: Squaring a corner with hand planes is easy - pics!
>The lesson that Chris Schwarz has articulated as rough to smooth - I know he's got a cooler set of terms for it, but that's how I remember it this morning - is sure an important one.
Nice work, Wilbur.
I betcha the Japanese temple carpenters have planes to do rough work, too - I doubt their wood comes to them S4S and Sq4S (square four sides).
ThomD
>The rough planes both japanese style and western get the most use aorund my place. The very finest shavings can only come off well preped boards, and it takes some heavy planing to get there. The Japanese, as Bill says, have some coarse planes and power planes to get the job done. I imagine they must have had the same coarse planes as we do also, though one rarely hears much about it. I made a coarse plane when I first started out in the 70s, and it has seen lots of use. The Japanese pull geometry is particularly brutal at getting a good hook in anything from fiberglass to pine, and it wil keep cutting even when dull. Needs a big mouth.
Robert Rothman
>I'm at the stage where I'm just trying to learn the basics, including using planes to true boards and square corners. I find that what tends to happen is as follows: I check the wood, try to identify the high spots, take a shaving or two from those spots, and try again. It needs a little more, so I take another shaving or two. This goes on for a while, until I try it again, and, OOPS!, I overshot! What used to be the high spots are now the low spots, so I take a shaving or two from the new high spots. And so on, and so on, going back and forth across the "just right" spot until what started out as a rough 2x12 winds up as a reasonably true toothpick. I'm exaggerating on the scale, of course, but the fact is that I keep crossing the point where the board is true, each time losing more stock in the process. Worse still, sometimes I reach a point of frustration where its close but not quite there, and I say, essentially, "close enough for jazz" instead of continuing until its really right -- because I'm afradid that if I do keep going, I'll overshoot the mark again and make it worse.
I assume that a lot of this is just the need for practice, but any specific tips would be appreciated. Thanks.
Greg B�tit, Crown Point, NY.
>Hi Robert,
My advice is to not obsess over perfection. I believe that is the trend for most people learning to use hand tools on their own or from a book. After all, most of what we see made out of wood has been machine made, the parts come tightly toleranced.
You have the luxury of knowing where the surface you are currently hand planing is going to fit in the end item. If it doesn't matter if that side is all that square, then spend your time where it is going to matter. Square enough is most often something less than perfectly square.
greg - who doesn't make "fine" furniture, so be careful how you take this advice.
wilbur
>Hi Robert,
Just to expand on Greg's point, Do you see in my "after" picture how the left side of that face still isn't square? I didn't fix that. That side is going to be the bottom of my workbench, and so won't show. I'll still have at least a good 2" width of good wood-to-wood contact for the glue up, which should be plenty strong enough. And since I was making sure that the corner between the top and the sides of the beam are square, I should have nice tight glue lines when I get everything cleaned up.
That is exactly why
Dan Donaldson
>My wife doesn't let me try to trim bushes on the sides of the sidewalk. Cut off one, then the other, whoops, too short, go to other one. Rinse and repeat til both bushes are only 6" tall ;-)
Nicely done Wilbur. Thanks for sharing!
Scott Burr in Ben Lomond, CA
