A55 Smoothing Plane
Conundrum. Help please!
Larry_Wyatt(Cole's Dad)
>I'm at a bit of a loss as to how to solve a problem so I thought I'd come to the great think tank on the web.
I'm building a clock(the one on the left with the inlay and arch)for my lovely wife. It will have a clock bored into a hole inside a round piece of cherry(??) and will sit on dowels inserted into the holes that you see. I was smart enough to bore the holes before cutting out the arch, BUT didn't test the fit of the dowels. Sooooooo, here I sit without a way to bore the holes a few thous larger. I know a Forstner bit would work, but the cupola of the arch would break I'm afraid, because of grain direction. I could sand it out, I suppose, but then the dowel fit wouldn't be good.
Feed me some great ideas, Seymour!!!
Larry Wyatt(Cole's Dad)
Houston, TX
Re: Conundrum. Help please!
Jack Guzman from Maine
>Why not make the dowels smaller to fit the holes you already have? Drill a hole the size you want in a piece of scrap steel and drive the dowels through the hole.Please show a picture of the finished clock. It looks interesting.---Jack
Patrick Gibbons, Katy, TX
>Another solution is to chuck the dowel in a drill press and use sandpaper until the dowel is sufficiently smaller.
>Leave it to a Texan!!! And from the electron-free side too!! This is one of the reasons why I move to using hand tools more and more every time I'm in the shop!
How-DY!!!
Thanks to all!
Larry
Or put the dowel in an eggbeater drill,
>hand the drill to your son, have him turn it as fast as he can, and sand it while he's whirling it.
ThomD
>You can hammer finish the dowel, just tap it while moving it around to reduce the diameter. The proper tool for the hole would be a chucking reamer, or some other kind of reamer. They actually stock them 1 thou ovesize, though for this kind of thing that would not be required.
Marv....... Northern California Lake Co.
>Larry,
Buy a number drill or letter drill that is a couple thousands larger than the dowel.
Or, like others have suggested, put the dowels in a drillpress and sand them smaller.
Another way to do it is to make a little sanding tool by sawing a slit lengthwise in a smaller dowel and slip a piece of sandpaper into the slit so you have a flapper sanding tool. The sandpaper would wrap around the smaller dowel in opposite directions. You can turn the tool with any means you have available to you.
Marv
A case for letter drills
Bill Tindall, E.TN
>Earlier I described why I own number drills. Letter drills fill in the gaps from 1/4" to 1/2". The reason I bought them is to solve problems like this.
Or.....the reason dowels are always too big is that they are turned from wood just out of the kiln and they grow upon acclimating. Put them in an oven for a while and they will return to the specified size. But, I have done this trick on a delicate piece and had it crack when the dowel re-expanded.
See Bill's post below!
Scott Burr in Ben Lomond, CA
Not necessarily
>Pammie would have have you burn it and start over.
