glue curing and really cold temps
Bruce, a MN Galoot
>It's been cold here in MN, last night the air temp hit -30F (-34.44C for the Fahrenheit challenged). Well, I have a project that I'm completing that I can work on while on the job (as long as I'm awake and can monitor our portion of the grid, no one cares what else I do) but it involves moving the night stands from work to home and back.
What I do is take the thing to work, glue something on and then take it back home. The question is, how long does liquid hide glue or even titebond need to cure before it can be subjected to freezing temps without harm?
Thanks.
Bruce, where the weather guys tell us the January thaw is on the way.
Re: glue curing and really cold temps
"the January thaw"
>Wish I could help on the glue, but I don't know - have you considered contacting the manufacturers?
Is the January thaw when it gets up to zero F?
Re: "the January thaw"
Bruce, a MN Galoot
>Minnesota folks actually expect thawing temps around the third week of January. Ice melts from driveways, but flowers don't blossom, so it's really not all that useful, just a reminder that this won't last forever.
However, the legislature is now in session so no one is safe.
You should come back to visit MN in the winter, Bill. I'll even pony up for some hot coffee!
curing theory
Bill Tindall, E.TN
>I don't know about hide glue, but for the yellow and white........
The glue is a water suspension of micron sized balls of solvent swollen plastic (polymer). The curing process involves first evaporation of the water (or the water diffusing away into the wood), followed by the coalescence of the polymer balls into a film. If the temperature is too low the balls aren't mushy enough to coalesce and the result is a sandy, weak adhesive layer. So, you need to keep the joint temperature above what ever is stated on the bottle long enough for this process to occur. I would presume this time is tens of minutes at normal temperatures, not hours or days because there is considerable joint strength even after 1/2 hour at 75-80 degrees.
To develop full strength, the solvent and water that makes the polymer mushy needs to diffuse away through the wood. This does take hours to days depending on the temperature and moisture content of the wood.
I would expect that hide glue cures by a similar process except the solvent and suspension agent is only water.
One can always answer glue questions with an experiment. Glue a test piece and subject it to conditions in question. Bash it apart and see if there is mostly wood failure.
I didn't realize it at the time but the first year I lived in MN there were 3 record lows set and it snowed in early May. I thought that this was normal and this was not a place I was going to continue to live. So I moved to TN where it is only going to be 0 tonight.
Re: curing theory
Bruce, a MN Galoot
>I just called Franklin and talked to a tech. He said essentially what you did, Bill, and furthermore that once a few hours had passed, there would be no problem, assuming that the piece would once again be put back into a room temp environment.
-44F in Bismarck ND last night. One of my friends said he even had to roll up the windows and turn on the heater in his truck!
Bruce
Re: curing theory
ThomD
>With tightbond, the glue squeezeout discolours orange on the surface if it is too cold. This happens long before the glue has any risk of freezing. When I used to build guitars in a cold shop, I decanted the glue into a small squeeze bottle that I could carry around in my pocket. That seemed to help. Of course it isn't always practical to let glue squeeze out. But you could always do a simultaneous test piece just to see what your average conditions do.
Hide glue curing theory
>Liquid hide glue, is not effected at all by freezing. If it frozen you can't get it out of the container, but I just removed a small amount from my refrigerator, warmed it up and used it.
It will take time to cure, especially at cold temperatures, feel the squeeze out and when it is firm to the touch, then it is safe for the joint to be subject to freezing.
That is the good thing about liquid hide glue, freezing won't hurt it at any time during its storage, use and life.
Stephen
Re: Hide glue curing theory
Bruce, a MN Galoot
>That is just what I wanted to know, Stephen. Thanks
bruce
Greg B�tit, Crown Point, NY.
>I have one experience that proves this right.
I read somewhere that you could get a good bond with hide glue on end grain. Not believing this, I sawed off a 1" square of maple from a surveying stick, and glued the end grain of the cutoff to the side of the stick with hide glue. That was at the end of the day, I had just used some Titebond yellow glue to join a couple 1/2" boards prior to this.
It might have been around 55 degrees F in the shop when I left it, and I didn't throw anything in the stove when I left. It got cold that night (not going to get into any boasting bouts with MN folks about how cold).
The hide glue *does* bond end grain. I use that stick to juggle the logs in the stove and that cutoff is a nuisance, won't let go. On the other hand, I noticed the squeeze out on the joined boards looked different (maybe kind of crystally, can't remember exactly), and gave one a fairly mild bend test. It broke right down the glue line.
I think that's when I decided hide glue was the way to go.
greg
"maybe kind of crystally"
Bill Tindall, E.TN
>Thats the polymer balls that never coalesced into a film because they were too cold to be soft enough to do so.
