Still Not Done....but gettin thar!
Frank Mutchler
>I didn't want to hijack Wilbur's thread so I thought I'd start one here. I�ve been semi-retired for the last 5 months and have had time to return to my garage/shop.
My bench was a solid core door on metal legs. I did not use hand planes on it but I did all types of power tool work on it. I nailed into it when I needed to (and sometimes when I didn�t), got all kinds of oil finishes on it, drilled into it, bored holes through it, used it for metal working as well as wood working, etc. It wasn�t pretty but it worked fine; except for hand tools, that is.
As I became interested in hand tools, I realized I was going to need a new bench and so I started buying material for my bench. (Think ground squirrel with his cheeks packed full of goodies.) That was at least 5 years ago. LV cast iron legs and two LV vises, a twin-screw for the end and a large front vise, and a pile of 8/4 x 8� hard maple found their way into my garage. I managed to mill & glued up the top before circumstances intervened and I had to take an extended break from woodworking (work related travel).
Well, I pretty much completed the bench during the last 5 months. The top is 3 �� x 27� x 86�. Round dog holes chase each other along the front & back of the top and a 1 �� x 7� apron is draped all around the top. I decided to build a small cabinet to make use of some of the space under the bench. I built the cabinet primarily because I�d never seen a LV cast iron legged bench with one! Contrary to warnings, the cabinet does not interfere with the LV holdfasts that I use nor does the apron interfere with clamping work to the bench top. I haven�t drilled any holes into the apron yet and I probably won�t until I need some. Still have to finish the face jaw on the front vise.
The apron does look nice, IMNSHO, and also adds significant weight to the bench. Figuring about 45 lbs/cubic ft., my top should weigh about 273 lbs. The legs, stretchers, cabinet & contents may add another 150 lbs making the entire assembly some 425 lbs. It�s a solid bench to work on.
The cabinet, melamine box/hickory fronts/mahogany pulls, is home to a couple of full extension drawers; each of which is about 2� x 2�. Lurking beneath them are two half depth cubby holes for misc. storage. The finish is 3 or 4 coats BLO & Turps mixed 50/50 which gives me a �non-skid� top. My garage is not heated and ranges from a low of 0 deg in the winter to 90 deg in the summer and, as far as I can tell, the top hasn�t moved a bit since I glued it up. Our climate does stay pretty dry year �round.
Re: Still Not Done....but gettin thar!
wilbur
>Boy, now I'm just embarrassed, showing the 3 4x4s I glued up. :@)
Your bench looks really nice, especially with the dovetails.
Frank Mutchler
>Wilbur, I guarantee you that the only person who might be embarrassed when comparing their work to mine is my grandson! ;>)
Look closely and you can see where I got happy with a chisel and chipped out part of the bottom pin. I'm going to fill it in one of these days. By the by...those were my very first hand cut dovetails!
Aircraft carrier!
Wiley Horne--So. Calif.
>Big milestone, Frank. Congratulations.
I think you will find the apron very useful for clamping stuff to, and the LV holdfasts will be a good complement to your front vise for doing so. Not only boards for edge jointing, but also panels needing to be trimmed (you can rest them on the drawers!).
I predict that a great deal of work will be done at the right front corner, and that you will find that the clamping space between the screw and the bench corner will be the most-used vise area.
Terrific bench!
Wiley
One fine lookin' bench Frank
Scott Burr in Ben Lomond, CA
>I tried to play with Hickory once myself. Thought I woke up in Hell.
You did a fine job on it and should be proud.
Thanks, Scott. It's just a tool ;>)
Frank Mutchler
>I like hickory and the drawer fronts are some left over scrap pieces. I remodeled our kitchen and made all the cabinets out of hickory; 11 full height wall and 8 base cabinets. That includes 3 Super Susans and 2 corner wall Susans all of which have hickory shelves in them.I killed a whole bunch of electrons doing it and I'm pretty sure I never would have been able to do it using just hand tools.
A side benefit is that I probably have a few years supply of scraps for the BBQ/smoker!
Oh Yea! Throw a pork chop on for me OK!
