Re: drill press
ThomD
>Drill press or guides as mentioned, but there are some alternatives:
- egg beater drill, the straight up and down of the center of this tool is easier to hit square with than any other. It's a preferable thing to an electric, for accuracy, but not quite there to replace a drill press.
- electric drill with built in levels. Sometimes these are pretty good.
- A boatbuilding device for all the odd shapes, is like a bar clamp and one end has a spike and the other an guide. You put the spike in the far side of the object, and the drill where one wants to start the hole. It keeps everything in line, sorta like drilling on a lathe, but portable.
- John Alexander's device where a bit extention has a counterballanced level attached to it, or just taped to it. It is easy to keep level, so the workpiece has to be orientable to level for any holes. The other angle is controlled by eye or with a cheater block. Probably better for angled work than a drill press.
