Dovetail DVDs - Recommendations?
Scott in Douglassville, PA
>Hi, all -
I need a recommendation for a beginner dovetailing DVD. Amazon's got several - Kingshott, Klausz, Cosman, Lonnie Bird. Anyone have a favorite? When I've done them before (limited experience, long ago), I cut tails first, FWIW.
Any suggestions? I want to cut the DTs for my upcoming desk project by hand.
Thanks,
Scott
Re: Dovetail DVDs - Recommendations?
go look on U tube
roninkokomo
That's easy....Cosman
Bill Tindall, E.TN
>Cosman
Our club has taught classes based on his approach and beginners find it easy. He gets you past the hurdle of layout with a foolproof approach and on to the real deal of sawing and chopping. We have never had anyone fail to cut acceptably functional dovetails.
There may be better ways for experienced persons (Klause for example) but I think Cosmans's approach is the easiest place to start.
Suggestions: Its all about sawing, so practice sawing lines. When it becomes boring you are ready to move on. Then practice on dovetailing any chance you get. I hand cut dovetails in all sorts of foolish projects (and foolish woods) where looks don't count. Personally I think the best way to learn is to use them in things where appearance doesn't count. It was after a few of these projects that I lost my fear of cutting too "close to the line", or just plain lost my fear.
If making dovetails becomes tedious and something you want to get on with (sometime down the road) band sawing out the waste on tails and routing out the waste on half blinds (Bird approach) are real time savers. Personally I don't find dovetail chopping, sharpening and root canals rewarding uses of time.
Getting your mind right that dovetails are a superior way to hold something together ( refer to English drawer construction discussion earlier), and not necessarily a way to show off you woodworking skills, will help you a lot. Use dovetails you find in antiques as a standard, not modern studio furniture, at least as a start.
Dean J in MN
>I'd like to echo Bill's suggestion of putting yourself in the state of mind that dovetails are just a way to hold things together. This, coupled with the suggested practice of sawing a line (or two lines at a time) will pay you dividends.
As for a DVD -- is there no one near you who hand cuts dovetails? I think a little time with someone who already does this is better than a lot of time watching a DVD. Seek out a person if you can -- if you're in my neck of the woods I'll teach you all I know for a beer. (Keep in mind, I know very little, so it can be a light beer!)
-Dean
Klausz & Cosman because
Frank Mutchler
>they demonstrate two different approaches to joinery.
Frank shows how simple cutting dovetails can be. Visualize where the cut should be and cut it. Rob appeals to the more persnickety (is that a word?) mindset. Precise even measurements using calipers, etc.
I like Frank's because his approach is the shortest distance between 2 points. Don't make cutting dovetails one of the mysteries that confound, confuse, and intimidate beginning woodworkers.
Great Advice!
Steve Elliott
This reflects my idea of "good dovetails" very well. Twenty years ago I was looking through a large antique store just to get a feeling for what kind of construction looked good after lots of years, and found a pair of nightstands that sold in Bristol, England in about 1910. (There's a little button in one drawer that gives the name of the furniture dealer, and the style is Edwardian.) The dovetailed drawers were done so nicely that it changed my idea of what to aim for. They were obviously cut quickly, given that some of the saw cuts overshoot the mark a little, but they are accurately done. The mahogany drawers are in the British style with thin sides and a slip to hold the drawer bottoms, and the pins are very narrow. They obviously weren't for show because the front joints were covered with black stain to match the finish of the show surfaces of the piece. They've done a great job of holding the drawers together for a century now and they're an inspiration to me. Previously I'd made some more-perfect looking dovetails that didn't have half the charm of these and they took me way too long.
ThomD
>Cutting pins first is the right way to do it and the way Klauzs does it, but if you prefer tails which seems to be leaking into popularity, then another choice might make sense. I don't think the Klauzs method is simple or difficult, but it is less constrained by things that get in the way of the flow. At the end of the day, the joints have to be tight, but not too tight, and that is the same challenge no mater who does it or how. The accuracy comes from getting to the point where the process flows, the saw is allowed to cut etc... The key is to find a method, look for the details, because often there are little bits that hold a method together, and it is best to try at first to follow through one method. Then it is just practice. The Klauzs method on layout is faster, so learning goes faster, though one is not likely to use if for fine furniture. I doubt he assumes that one would.
One thing I would recomend is the Frid tapes for cutting half blind. Through dovetails are not used that much in serious furniture, though i love them. Or they are hidden away behind moldings or in the back of drawers. So HBs are important. Frid has two tapes one about 10 minutes from FWW, and a one hour one like a bio, that has the same segment in it, also from FWW.
Kingshott. Nuff said.
Scott Burr in Ben Lomond, CA
>We talked about this some time ago and now young padmay(SP), it is time for the master.
Besides unlike a stuffy and very uptight Cosman (although you'll get to see Eddie or the likes of) I got it too if'in you want to borrow it. Jim's got a great seance of humor and far easier to watch and much more in lighting IMHO.
Don in Vancouver,WA,USA
>A LN DVD: Chisel Techniques for Precision Joinery by David Charlesworth is as good as you will find. You will learn a lot more than making dovetails!
How slow
David Cockey
>Depends on how slow you want to go. Charlesworth is ever so precise with the chisel. Cosman just saws the joints, cleans up the bottoms with a chisel, and puts the joints together. From what I can see from the videos there isn't much difference in the final results.
I've gotten a fair amount from several of Charlesworth's videos, but I find him somewhat finicky.
Re: How slow
Pam Niedermayer, Austin, TX
>I feel the same way about Cosmo, what with all that divider based layout applied multiple times. Way too fiddly.
Pam
In defense of the Cosman approach to dovetails
Bill Tindall, E.TN
>This response is from the perspective of having taught rank beginners how to hand cut dovetails. Let me also say that I am sure that nobody that has assembled 100 drawers still uses all the Cosman steps on the 101st. Which is to say there is a world of difference helping someone to successfully cut the 1st vs what a professional does.
There is a bewildering (to the beginner) number of things to worry about. The Klause approach of, "just eye ball them" and get on with it is not helpful to someone that has never held a dovetail saw.
Cosman's approach provides a road map to successfully get through the mechanics of layout and marking and on to the hard-to-learn part of sawing, chopping and fitting. In an hour I can have students worrying about these hand skill issues and practicing on a joint they have laid out.
There is simply no argument that tails first is easiest to learn to saw. So,by combining Cosman layout and marking and tails first sawing someone with no experience can produce a serviceable joint in 4 hours. And they can go home with enough knowledge, and confidence, to lay out and saw more practice joints if they have continued interest.
And, with experience they will shorten the layout and marking process and maybe even switch to pins first sawing. But, the "crutches" Cosman provides will get a beginner more quickly on the road to success, with more confidence, than an approach used by a professional to make drawers on a cabinet he/she needs to sell to buy groceries.
>The reason I prefer Charlesworth is because his "finicky" delicate precise approach offsets my low skill level bull-in-a-china-closet style. I only occasionally play at being a woodworker but I like twisted dovetails and rising dovetails that put a premium of layout and rendering accuracy. I wrote my own software that prints out layouts that are glued onto the boards that are to be sawed and chiseled. We all have very different approaches largely defined by our backgrounds...I only wish I had some of David's skill!...Don
Re: How slow
David Cockey
>Charlesworth is way slower and more deliberate than Cosman. Charlesworth seems to be of the cut wide of the line and then pare to the line school. Cosman cuts the sides to the lines, the bottom close with a fret saw, and then quickly pares the bottom.
Cool Pic thanks for posting!
Re: How slow
>Thanks, David, I can save some more money. :)
Pam
Re: In defense of the Cosman approach to dovetails
ThomD
>"The Klause approach of, "just eye ball them" and get on with it is not helpful to someone that has never held a dovetail saw."
Actually I believe it is ideal for beginners. It forces them to rely on their skill rather than trying to escape it. It is a bit like talking about sharpening with a jig or without. If a person wanted to learn the without method they need to get in touch with their hands. All the training wheels in the world will just slow them down. There are a few problems though:
1) Some people just won't try a free approach, as though wasting 25 cents of wood were a tragedy. This speaks to the idea that people have different ways of learning. Some people may be open to trying something that expands their abilities, some people won't do it because it hurts their feelings about who they are as a woodworker. And people come to learning in more or less physical ways. Overall a person may be better to practice their weaknesses, but people seem to prefer practicing what they can already do.
2) Most people don't want to learn how to make dovetails, they want to make dovetails in the context of a particular project, often with valuable wood at stake, whether because it is nice, or already has some work invested in it. So that requires a stilted and damage controlling approach to the problem. It would be as though one wanted to learn to ride a bicycle, but had to come up with an approach that would allow one to never spend a second in practice and start instantly one a tour across America. That would require something a little different in learning approach than just winging it on the driveway.
"Cosman's approach provides a road map to successfully get through the mechanics of layout and marking and on to the hard-to-learn part of sawing, chopping and fitting. In an hour I can have students worrying about these hand skill issues and practicing on a joint they have laid out."
Really layout and making are two completely separate things, as you know. Klauzs method does not come up with a harder method of laying out, it basically comes down to two things:
1)just make a messy layout. Fine for practice, bad for projects. So for anyone really just practicing, dividers or templates are of no practical use. K's method does not adapt to all situation where dovetails are cut. It is just a method of doing layout, layout free, where that is appropriate.
2) Does one need a pencil line to saw a straight enough line. At root here is the issue of whether pencil lines on wood straighten out sawing, and the whole sighting and aiming point theory in woodwork. I would say more often than not the answer is that lines are much help:
- Some saws are so tight that they don't steer, so getting back on line is not possible;
- Another important point is what are you aiming at when you follow the line. In general, if you want to hit something off in the distance (like the precise point you are trying to reach at the bottom of a cut), you are better off not looking at where the saw is cutting in relation to the line. There are two reasons for this. One is one is not projecting the cut in the right direction, as accurately as if one simply stared at the arrival point, even a rough idea of where that arrival point is. Also, the area one is looking at the distance between the line and the edge of the saw is very difficult to judge. one is far more likely to wiggle back and forth, and make a rough line. Another good place to focus on at times is the space between the blade and the kerf. Is the saw stock parallel to the kerf. Only works if one started well.
So to what extent is the line helpful? I think it is helpful once one has learned the behaviour that gets one on target. It can be a trap for the beginner though.
"There is simply no argument that tails first is easiest to learn to saw."
I would have thought there was ample argument on that point. I tend to fall into the camp that if there are two opposed warring camps that say only one way is possible, and both seem to manage, then I come to the conclusion that there is no right way. I do find the emergence of the tails first school odd. A number of people as natural contrarians, seem to have bristled at the idea one had to go pins first, and tails first is the route they pursued. Even if pins first were harder, and I see no reason why that would be the case, there is only one truly hard thing about dovetails an that is getting the saw cuts nice with the correct fudge factor so they come together as a joint. Everything else is a nothing in comparison. In one's woodworking career one is likely to have to make cuts that look like starting on the tails, and cuts that look like starting on the pins. I see no reason why anyone would fail at the task, once they got underway in the craft.
"So,by combining Cosman layout and marking and tails first sawing someone with no experience can produce a serviceable joint in 4 hours. And they can go home with enough knowledge, and confidence, to lay out and saw more practice joints if they have continued interest."
Four hours should be enough time for any method, but you are to be commended for teaching others. My only thing about that is that learning from a video is a different deal. If a person wants to learn from video, or books, there is something to be said for sticking to one method only rather than trying to invent some hybrid. Pick a demonstrated method and stick to it in every detail, because the method shown in the tape works. One thing about Cosman and Klauzs is that both, to my way of thinking are really demonstrators. I am not sure their methods are principally teaching methods. You, Bill, are at least addressing the issue of the best way to teach something.
