Some workbench top progress
wilbur
>I made some headway in gluing up my workbench top this weekend. I learned just how much wood can twist and bow after you do initial milling. I also got a lot more practice at correcting this twist with hand planes, if you know what I mean. Although I know I know this, I am really surprised as to how quickly I can square up something this large with hand planes. In some ways, it was easier than the initial milling up with my jointer/planer combo.
The other thing I learned is that if one of my planes is working in a less than optimal manner, I know how to correct it. For some reason, though, I insist on just plowing ahead instead of stopping to tune up the plane, until I get to the point where I just have to do it. Then I find out that I'll zip along three times as fast as I was.
As you can see in the picture, I'm also learning the true meaning of the phrase, "You can't have too many clamps." I placed an order for some more today. Hopefully they'll get here in a timely manner.
All together, there will be eight 4x4's going into this benchtop. I'm planning on gluing one additional beam a day, partly because I only have so many clamps, partly because of space issues (the picture really shows the entire width of my shop) and partly because I want to get a full day of drying time for the glue, just in case I didn't take care of all the twist. I'll probably do another set of three separately, and then finish up with the remaining 4x4s.
To get going on this, I clamped together most of the 4x4's together on the sawhorses to provide a temporary work surface, squared up two of the beams, and then unclamped the other 4x4's to give me room to use the sawhorse as a support for the glue up. In fact, I had put the bar of the clamp on the top side so it could be used as a planing stop.
Stephen's suggestion on jointing the top of my sawhorses was also really helpful. Thanks, Stephen!
Re: Some workbench top progress
Stuart Hough
>Looks good so far, Wilbur! Pray tell...what species of wood are you using? And, 4x4's! I've thought of that, but it seemed like overkill. What are the final dimesions? Thanx for the pic, and the answers.
Memory lane....
Frank Mutchler
>You're doing great, Wilbur.
I can relate to your comment, "For some reason, though, I insist on just plowing ahead instead of stopping to tune up the plane, until I get to the point where I just have to do it. Then I find out that I'll zip along three times as fast as I was."
Don't do it as much as I used to (gray hair now) but you're certainly not alone there.
Been working on my bench for the last 4 or 5 years. It's quite usable now but still not done. Am glad I made it but would think long and hard about milling/gluing up/planning another top! Trouble is, I don't think you can buy a 3 1/2" top.
wilbur
>Hi Stuart,
These are kiln dried Douglas fir 4x4's from the borg. I'm guessing that the final dimension of the top after I get it all flattened will be about 3-1/4" thick, 22" deep, and somewhere between 6 to 7-1/2' long, depending on how I wind up locating this bench in my shop.
The 4x4's may seem like overkill, but actually they are a sign of laziness. I wanted my top to wind up being 20-24" deep. Using 8/4 stock that would have meant twelve pieces of wood to glue up. Using 4x4's, I only need eight, which means less work for me! :@)
I'm glad no one has noticed the awesome amount of glue squeeze out that I got. I'm still trying to optimize the amount of glue needed for each joint.
Victor Parisian
>Looking good. I to am working on my bench. Last evening I worked on the leg vice 12/4 8" wide ash. got the taper done and contemplating the locations of the mortise for the spacer board. See Swartze' Workbench Book for details.
Victor - in sunny (fttb)Houston
Dominic in Bucks County PA
Lookin good Wilbur!!!
>Man, that is going to be one MASSIVE workbench top! Keep us posted on your progress!
See ya around,
Dominic
I don't think you can buy a 3 1/2" top *LINK*
charlie belden
>Well you CAN get 1 3/4" thick Lab Bench tops and do two layers to get to 3 1/2". And you don't need 3 1/2" acrossed the whole bench top - not a lot of pounding and wacking in the center of the bench top. It's the front and back thirds - where dogholes are - and where the wacking and hacking and hewing are done -that the extra thickness is needed.
And if you need more thickness to reduce sagging along the long side - you can make a thick apron front and back to help with that.
You going to use AllThread through the 4x4s? Comes in handy for connecting the aprons to the bench top core.
And that gets us to the "frame" around the core. You going to breadboard the ends of the core - or spline them to ends which are joined, preferably with dovetails, to the front and rear aprons?
Funny how a workbench seems so simple and straightforeward - until you start thinking about how the wood may change dimensions - and what is needed to keep things from sagging, twisting, cupping, bowing etc..
Would it have been better to start with the pedestal/base of the bench and then be able to use it to built the top?
Sure hope you already have, and have a way of accomodating, your vises. They can get tricky if everything's together before you get to them.
Fun making a woodworking bench. Odd that having one already would make making one SO much easier.
Enjoy the build!
1 3/4 + 1 3/4 = 3 1/2
Stuart Hough
>All the 4x4 in my local borgs are PT. Bummer! That would have save me a BUNCH of time!
Ahhh Wilbur, some true words of wisdom...
Scott Burr in Ben Lomond, CA
>In your post. I think we all learn the hard way some of the things you have brought up. Especially for me about taking the time to get your planes properly tuned and set up. That has caused much frustration in the past. You got a great start on your top, and there are creative ways to create clamps when needed. Bungie cords, the family car etc...
Re: I don't think you can buy a 3 1/2" top
wilbur
>Hi Charlie,
This workbench is going to be a Roubo style bench. No aprons. The legs are directly mortised into the top. No dogholes. I'll be putting in some holes for holdfasts. I picked out the 4x4s so that they are all nearly quartersawn, so I'll wind up with a top that should behave like a 22" wide quartersawn piece of wood.
I went back and forth over building the top first or the base first, but I figured it would be better to build the top and then dimension the base to fit the top I wind up with.
Bob Entwisle in NJ
>Nice progress wilbur. Those wetzler clamps are amazingly simple, fantastic machines, aren't they? As to glue squeeze out, don't thin down the glue so much that you starve the joint, thats worse than having to clean up the squeeze-out.:)
Mike Jurnigan in Suffolk
>I bought a 3' x 12' x 3 1/2" top from Bally Block in hard maple. They had to load in my trailer with a forklift and it took three people to unload it by hand when I got it home.
Wetzler clamps
wilbur
>I just love these things. I really like the fact that they don't have the little metal tabs that you have to pull back to move the jaw of the clamp back and forth on the bar. They are to clamps what Lie-Nielsen and Lee Valley are to planes.
Better than jorgies?
>I'm looking to up my collection as well...
Re: Better than jorgies?
wilbur
>I like Wetzlers better than Jorgies. Here's a picture to show why.
These are pictures of the Wetzler #4 quick clamp, which are the ones I have, and have a 4" reach, and the Jorgensen Deep Reach Steel Bar clamp, which has a 5" reach. Jorgensen has a similar clamp with a 3 1/2" reach as well. Note that the Wetzler does not have that multiple disc clutch that the Jorgie has. This makes sliding the jaw much easier. All I have to do is tilt the jaw slightly and it moves, and then it stops where I want. I don't have to deal with pressing on the disc clutch.
Jorgensen has a clamp that does not have this disc clutch, but it only comes in a 7" reach, and that was too big for what I wanted. All the Wetzler quick clamps have the non-disc clutch feature, whether they have a 2" reach or a 12" reach.
One other thing
wilbur
>Notice the little bump at the end of the top edge of the fixed jaw on the Wetzler clamp? That allows you to rest the clamp on its head on a flat surface when you are doing a glue up, and will keep it from falling over. That's a really nice little feature.
Thanks Wilbur!
>Wonder if'in i can paint them orange to match the line-up 8^)
