Pitted chisel - worth the effort?
Scott in Douglassville, PA
>Hi, all -
I bought an old Greenlee chisel for a couple bucks a while back. Advertised as having "a little surface rust". I doused it in phosphoric acid, and saw that the extent of the rust was much worse. There it has sat until now.
So, I had at it with some 120 grit drywall screen. After a couple minutes, I had what you see below. I'm wondering now if I (a) should continue lapping, trying to eliminate all the pitting, (b) sharpen it and use it as-is, 'cause the pitting is inconsequential (or is it?), or (c) use it for opening paint cans.
Any advice?
Scott
