Nicholson Bench: Front chop
Bjenk Ellefsen
>I finally have time to finish my bench.
I am trying to evaluate how long the front chop for the vise must be?
I am installing a twin wood screw front vise. I have measured and calculated a ratio from a photo of one of the benches at Williamsburg. I arrived at 24 inches. My bench is 8 feet long. Does that sound right?
Re: Nicholson Bench: Front chop
Dean J in MN
>That sounds reasonable -- more important -- will that length of a chop cause your hip to run into the vise when planing? In other words, the interaction of the placement of the planing stop and the chop is a consideration.
-Dean
Bjenk Ellefsen
>Thanks Dean,
I am trying to evaluate just that as I have not yet installed the planing stop. Under 24 inches and the chop seems to short for the big screws, over that and it will be in the way when I plane boards., it seems.
wilbur
>My feeling is that for a twin screw vise, the important distance is not the length of the chop, but the distance between screws. That will determine how wide a board you can clamp in it for dovetailing. Chris Schwarz suggests having 24" between the screws, which would make the chop longer.
Dean J in MN
>Yes, I'll second the notion that the distance between centers is another factor. It is nice to be able to fit a case side (~18") between the screws and clamp out any cup when dovetailing a carcass.
So, you'll need to balance all those factors when you decide where you put the vise and the plane stop.
(Or just shove the vise all the way over to the right like I did -- a la Moxon -- not in the way and I have 24" between centers).
-Dean
Bjenk Ellefsen
>Great insights!
Thanks!
