THE WOODRAT IS BACK!
how to make dining table with leaves
Bill Tindall, E.TN
>Daughter wants a dining table, square with rounded corners, that can be extended in length by the addition of leaves/inserts/whatever. What are the options for constructing a table that can be extended? It would seem that it would call for some sort of hardware enabling it to be pulled apart and leaves inserted, but I have never seen for sale what ever might be required.
Re: how to make dining table with leaves
Jim in Burlington Ont.
Norm had a nice one
>One of Norm's episodes had a nice dining room table with extenders made of wood. LV also sells them.
http://www.leevalley.com/hardware/page.aspx?c=1&p=40139&cat=3,43586,43593
>I think some of the hardware companies, like Rockler, make slides for extension tables. I'd search on "extension table" on their sites. I also saw, in one of the magazines, the use of heavy duty drawer slides fastened to struts.
We have two tables inherited from family. LOML and I have the pedestal table from my grandmother, and it rocks - the joint of pedestal parts (it splits into two parts) to slides is under considerable stress, and I don't quite know how you would make a joint that could hold up over time. Our son has the table from my parents, which has legs at each corner, and I think has one leg in the middle under the slides - much more stable.
These both have loose leaves that then need to be stored somewhere.
Another approach, not very common, is what we have in our original dining room table: the rectangular apron is solid, like a non-extending table. The top is split in two, and slides on slides atop the apron, opening to reveal a leaf split at 90 degrees to the opening, that then rotates up, opening as it goes, to fill the space. I have no idea where you would find hardware for this, and it opens up just enough to add one more person on each side, but it has the twin advantages of being very solid in use and having the leaf stored in the table. It also has a kind of cool gizmocity factor, but that should not be the reason to choose it.
There's also what Tage Frid called the "Dutch pullout" (and others apparently call "Tudor style"), which mounts the top loosely on dowels that allow it to rise up when you pull leaves out from beneath it and then settle down again - these leaves expand out each end, and are mounted on cantilevered struts.
If you can find a copy of "Fine Woodworking on Tables and Desks," which is old enough that your library may have it (it's also on half.com - for some reason, it's got two price points - under $10 and over $50), you'll find several articles from the black and white days on extension tables. The one that blew me away was the 4 foot circular table that extended out to about 12 feet.
My knowledge is all observational and theoretical, although I had in mind a circular table as a someday project to replace our existing one when I bought my Stanley No. 20.
Dean J in MN
>http://www.paxtonhardware.com/products.asp?dept=413
http://www.rockler.com/product.cfm?page=769&filter=table extension slides
Like those Bill???
-Dean
R.J. Whelan
>Bill .... Rockler and Woodcraft have this hardware (I'm sure there other sources as well).
If you look at the detail on Rockler's site I think you'll be able to visualize a couple of ways to make your own hardware out of hardwood.
I build a couple of dining tables a year and have made my extension slides out maple (think sliding dovetails) for the last several years. I think shopmade slides are superior to anything you can buy as you can design in a far better solution to holding everything level (in the leafs installed configuration) than any hardware I've seen.
The only downside to shopmade slides is the need to wax the slides periodically and the time and material it takes to build them. I'm pretty sure I can buy hardware for less money than the materials and my time take. In my case, I don't think the difference is very great, and the small increase in overall cost is outweighed by the smoother operation and better support.
Good luck with you table ... rj
Bob Rozaieski
>Does it need to split in the middle and have leaves? What about company boards that attach to the ends to make it longer? These would require no special hardware at all. Everything needed could be shop made from wood and a couple sturdy screws.
thanks all....very helpful
Bill Tindall, E.TN
