Re: Clock face sources - make your own of metal...
John Aniano - in NJ...
>Michael,
For certain types of tall case (grandfather) clock dials, many were made of brass and etched. Now, don't say that is too hard to do - I made several including a tall case clock face, with moving eyes on the sun/moon at the top.
Start with sheet brass of some nominal thickness, say 16ga. Cut to the full size of the dial. Clean the front surface well and coat with a layer of resist, a lacquer that resists the etching acid to be applied later. Scratch through the resist with compass points, ruler-guided scribes, etc., until the dial pattern of numerals and rings are to your satisfaction. Make sure you sign your name! Then use a brass or copper etchant to take away the surface of the metal exposed through the resist. Wait until the level is just below the rest of the surface and neutralize the etchant. Use a solvent to remove the lacquer and then heat the dial and apply a coating of black sealing wax or other contrasting material to the etched regions. When cool, level out the sealing wax using sandpaper and a wood block. Buff up the metal surface or use a scotch-brite pad to give it some texture. If you are really into this and cannot get enough of metal working, find the chemicals to do a thin silver plating of the brass and this makes the contrast between the filled etched regions even greater.
The chemical etchant was easily available years ago at Radio Shack for making printed circuit boards. I can't even remember what it was called - probably not great to breath or work with - I do recall using heavy rubber gloves.
Or you could paint the dial...
Take care,
John
