On the utility of owning a set of number drills
Bill Tindall, E.TN
>There have been several posts on the main forum where the solution to the problem was using a number drill. I was surprised that some woodworkers didn't know about these drills common to metal shops. I use them regularly in my "egg beater" drills so this topic is appropriate for this group, though the traditionalist will no doubt find some fault with their usage. All I can saw is because I own these handy devices that I never break or strip brass screws. Nor is there risk driving 18 ga brads, or any other nail, into hardwood if the pilot hole is perfectly sized.
Number drills are metal drilling bits that fill in the gaps of diameters between 0 and 1/4" not occupied by the fractional drill sizes. They are numbered 1-80 in decreasing size and they can be bought in sets of 1-60 and 61-80. It is a good bet that between the fractional drills and number drills one can drill a hole within 0.003", or less, of any diameter one chooses/needs.
I find them indispensable for woodwork. Take a recent example. I was installing Accuride drawer slides with flat head "sheet metal" screws. I used miscellaneous wood for the drawer sides and case so the screws were penetrating wood from oak to poplar in hardness. (this thing is a box to hold my lathe tools so don't get excited that I'm putting Accuride slides on fine furniture. It sure ain't going to have piston fit drawers)
With my digital caliper I measured the total diameter of the screw at 0.163" and the shank diameter (total diameter less threads) at 0.117". So ideally the pilot hole would be drilled 0.117" and it was a simple matter to find a number drill of this diameter. This diameter worked perfect for the softer woods. However, the oak was too hard for the entire thread depth to cut into it so the 0.117" pilot was too small. Using a scrap it was easy to find the right diameter for the oak pilot holes by trial and error. I use the same process to drill pilot holes for nails and brads. When installing hardwood trim I typically have three hand drills with number drills ideal for 16 ga. brads, #3 and #6 or 8 finish nails. The advantage is no split wood or bent nails because the pilot hole is too small.
If you only own a set of fraction drills the steps between sizes is too large to select a drill ideally suited for pilot holes. The result is too often wrung off screws or stripped slots. Ditto for brads and nails except here the bad result is too loose, bent nails or a split piece.
There are "letter drills" that fill the gaps in the fractional drills from 1/4 to 1/2" but I use these less. One handy use for them is fitting round tenons such as might be made on a lathe. I have a bad time hitting 3/8" exactly for example. Doesn't matter as some letter drill will match the actual tenon diameter.
Re: On the utility of owning a set of number drills
Great tip! My favorite number drills...
David Barnett - SW Florida
>...are the shorter screw machine drills instead of jobber length. Less flex and wander in the smaller sizes and nice fit to eggbedaters.
Several dealers sell index sets of mumbers (0-60) and sales often cut prices in half. I also suggest 118-degrees grind for soft materials; wood, brass and so on. But 135-degreed can be reground as needed.
Oh... and excuse my typing...
>It's not apt to improve, either. For now, though, I'll give it a try until oy hrfd ypp nsf (just kidding).
Only Philadelphia tool sellers
>sell index sets of mumbers.
Bill, whose LOML introduced him to the Mummer's Parade years ago - the largest small-town parade I know of, and the reason that Philadelphia may have the world's largest concentration of bass (and a few contrabass) saxophones.
Another vote for number drills
>I discovered them when my father gave me one of those 115-bit sets from Horrible Fright, but I was sure glad to inherit a proper set from my uncle.
The small sizes require considerable delicacy in use (as in, I've broken my share of them), but my local Ace hardware store sells replacements, as will most industrial supply stores.
The biggest problem is figuring out the size if you take out more than one at a time. There are drill gauges, not too expensive, to help you confirm sizes.
pin chuck
Bill Tindall, E.TN
>It helps to use a pin chuck for the little ones. The drill can be slid into it so that only the length needed is exposed. I recently drilled some 0.020" holes for brass wire this way (to make loops for hanging turned Christmas ornaments).
