We value your privacy.
>So, this is the last phase of new shop construction... I've been waiting to build this thing for over a year now. And after the Sjoberg Elite disappointment, this is right on time. Unlike the Solid Ash, Schwartzian Roubotzappfel benches I've seen lately, this is a pretty small bench, with simplified construction for the most part. But that's not to say that the Schwartz book didn't come in very handy. It's 2'x6', with a 2.25" thick bally block for the top. Plain jane borg 4x4 stock, milled down, to make the frame. The jaws for the twin screw are made of ash.
I had to notch the rear vise of the twin screw vise to get it to straddle the top of the leg, in order to sit flush. (easiest way to accomplish that) And I had to notch the bench top to set the vise in.
I still have to do things like drill dog holes and make a chop for the tail vise, but for the most part, it's done.
The last bench I built had a 1.25" thick top, scavenged from a butcher block desk. And this is the new bench next to that bench. The joinery on the old one was a lot sloppier, but it was cut with a $20 saw from the borg, before I really got going at North Bennet. That said, the design, and the joinery hasn't really changed, with the exception of the bolts that hold the ends of the frame together... the new bench has machine bolts and nuts, instead of lag bolts.
The vise is missing from the older bench, because it's now on the end of the new one. Then again, that vise was a replacement for a 7" quick release vise that had been mortised into the right hand end of the other side of the bench, and is now in a friend's basement.
Other details... the tool chest in the new bench is my NBSS tool chest. The drawers in the old one came from 2 sources. The black drawers on the left came from the same desk that I got the top from. And the small chest on the right was a small tool chest I built in a NBSS workshop... and it's the piece that finally got me accepted intot he full time program.
The stretchers on the old bench used to be situated in a lower position, but I had to raise them up when I installed the bench as an outfeed table in my last shop. The stretchers on the new bench are optimized to allow me to use a pallet jack to move the bench around if I need to.
The feet on the old bench are adjustable casters. There are no feet on the new one... I just made a chamfer cut at the end of each leg to prevent them catching on anything while being dragged around, and splitting out.
Aside from dog holes and such, the only other thing that I want to add to the new bench is a planing stop... the old bench had one made out of purpleheart, and I used it for a lot of different things... so I think the new bench will need one soon. Just trying to figure out if I want to use a "fancy" wood, or something plainer.
>Seeing a nice new bench (and this certainly qualifies!) makes me want to build a new one. Such a great project. Unfortunately, I have no idea how to make one with my lathe.
A new bench is on my sometime list (not about to say "round..."), though I want to experiment with some vise/stop ideas on the current top - meaning continue the ruination of the current top, so I can have a cleaner top on the next bench.
I also want to return to a leg vise. Used my grandfather's bench for some years, and I remember that leg vise fondly; I plan to re-use his (metal) vise screw (turned, I believe, by my uncle, who was a machinist), but build the vise slanting to address wide panels better. At least, I think so. Maybe I'll just go all nostalgic and re-use his front vise jaw intact.
>I've seen pictures of some impressive stuff done as face plate turnings by a guy who made a lathe that used a ford 9" axle. Talking turned patterns in a wall panel, other 6-8' diameter work cut into chairs, etc, etc... I'm sure you could make one with that. :)
>I thought I wanted something larger before, and bought a big 8 footer. I found it was a bit too big for most of what I was doing.
That said, my area in the shop has a couple of auxiliary work tables, and we have a couple of rolling assembly tables kicking around, too, and the big 8 footer is located in the machine room...
