Through mortise
Through mortise
Through mortise
chichi
>Besides perfect layout on both sides of the board and meticulous paring to the line, what tricks are there to make through mortises for say tusk tenons tight enough to not show light yet loose enough to allow the tenon to slide in without splitting the mortise piece (as I did)?
Is it fair to slightly taper the tenon so that it slides on easily at first yet fills the void when the (larger) base of the tenon is in the mortise?
Do you lay out a slightly smaller mortise and pare at the mortise ( or plane the tenon) as you sowly fit the tenon. This process took me a long time and surely there is a more efficient method than fit and pare, fit and pare?
What is the magical solution?
Thanks,
Bob
Re: Through mortise
Re: Through mortise
ThomD
>Splitting is obviously caused by too much width. That is also the axis along which any differential issues in wood expansion would show up. So you want to go easier on the parallel to wood grain axis than you do on the perp axis which can be extremely tight if so required.. When working production style I would use a mortise machine to cut the mortises and I would bandsaw the tenons, and fit them on the router table. By hand I would use the foot mortiser, or mortise chisels, no paring of the mortise normally dimensions are set by the tools in all cases. I would hand saw the tenon, and use either a router plane or hand plane to clean the mortises. I have often thought that a router plane set in a table would be pretty useful. It might actually be possible to set the LV router in their router table, since it just used hold downs to secure the router. When using the power router is it removing whiskers of material so the power part is not all that helpful, and a lot of routers do not present the bit dead square which leads to further disappointment. The table is great because once one tenon or scrap is fit, every subsequent piece is perfect. The bad deal is that it doubles inaccuracy, and it depends on stock preparation to be perfect, but if you have that taken care of, your golden.
The take away would be to determine mortise precision from the chisels and the tenon gets a final fit. It shouldn't be an endless process of fiddling or something is wrong. There are a lot of steps but they should all be pretty automatic.
Re: Through mortise
et's cover the simple ones first shall we...
Scott Burr in Ben Lomond, CA
>Depending how your doing your through mortia let's start on how I do them. Not saying this will work for you but, I never had a problem doing them this way up to 4" wide boards. First the stock must be flat. Absolute square comes after the fact kinda sort anyway. Mark the mortises on both sides of the board. Drill half way through one side then the other. Square/ even the sides with a chisel the WIDTH of the morti. If needed pare the sides but, I can't recommend this way about it unless utmost care is taken. As for the tennions... Saw them to the width of the mortise and start the fitting process. If it's not a structal joint you can dish the tennions a bit to help with fitting. Just make sure the exit part is tight with the mortise. Make sure their pinned (drawn) well any way you go about it.
Re: Through mortise
Question
Bill Tindall, E.TN
>I was interested in an answer to this question because making such a joint seemed impossible (along with a lot of other things experienced cabinet makers pull off to my bewilderment). It must involve a trick or skill beyond my imagination, I thought.
I remain bewildered by your explanation. As I understood.....we have the mortise marked and drilled from each side. Then we establish the long dimension of the mortise with a chisel. Then we jump to fitting the tenon! Don't we have scalloped sides to the mortise at this point left from drilling which we were warned to avoid paring with a chisel? What is done to establish the short dimension of the mortise and get its sides smooth and uniform?
Where did my reading comprehension fail me?
Re: Through mortise
Re: Question
chichi
>Thanks for responding. I agree with Bill. I also missed the point about the procedure for the short sides.
Bob
Re: Through mortise
Bill and Chichi...
>The short sides are formed by the chisel. If need be, one can belly or hog out a bit of the center of the tenon. Sorry for the vague explanation.
I received a offer to become a "real " employee and get out of my contract gig yesterday, so being very happy I was offered a full time gig I had a couple of cold ones in me when I first posted.
Hope this explanation clears things up, not me drinkin but how to make a big through mortise.
Re: Through mortise
Congrads on the employment offer...
Victor Parisian
>Nice going.
Victor in Houston where the sun is shining fttb.
