Window stool angled rabbet
VTAndy4
>I'm about to make window trim for 2 new windows. Does anyone have any experience with cutting the angled rabbets on the stools, to fit the angle of the sill? I'd like to do this with hand tools.
-Andy
VTAndy4
-Andy
Re: Window stool angled rabbet
Warren in Lancaster, PA
>Andy, it is sometimes trouble to replace machine made parts with hand tools. I like a good thick sill that levels off where the stool sits so this problem does not occur. In your case, I would plough a rather wide groove in the bottom of the shoe the full depth (that is going beyond needed clearance for a portion) and then use jack plane and rabbet plane for the slope. This leaves a small cavity inside the assembly that will not be seen once all the trim is on.
VTAndy4
>Thanks, that will do the trick! I'll give it a try this afternoon and let you know the results.
-Andy
Bill Houghton, California cold in Sebastopol, CA
>I use an approach similar to Warren's, but if your sill is 90 degrees at the top (that is, slanted in both "horizontal" and "vertical" directions, you can cut and plane a slanted rabbet. This requires a pretty thick stool, though it does give you the advantage of a joint that slopes out to the weather, good if the caulk in the joint fails.
Pam Niedermayer, Austin, TX
Hey, guys, I have to make some windows very soon, so I'm trying to follow this; but the terminology is confusing me. What precisely are: sill, stool, shoe, and slope? Perhaps you can point me to an online drawing?
Thanks,
Pam
VTAndy4
>Hi Pam,
Go to "google books" and search for a book called "Trim Carpentry Techniques" -- it's got some very good diagrams of windows.
-Andy
>The pic illustrates a double-hung (presumably) window.
The sill is the slanting part that's exposed to the weather; the stool is the inside part, on which you put your tchotchkes or, if it's wide enough, house plants (also suitable for cats to sit on while gazing at birds outside).
I'm not quite sure what Warren means by "shoe."
"Slope" is just what it sounds like - a sill needs to slope out to the weather - to the outside of the house - so that water runs off.
This illustration (from an early-in-the-last-century manual trades text) illustrates why the angled rabbet that Andy asked about is useful - any water that gets past the sash, or runs down the inside of the sash from condensation, will tend to run down the sill rather than into the joint between sill and stool. As I mentioned, although my recent windows used the approach that Warren does, flattening the top of the sill there the stool will sit and caulking vigorously, an alternative is to make the rabbet a 90-degree rabbet but slanted relative to the surface of the stool, at an angle that matches the slant of the sill.
One defect in the frame as drawn is that there's not a drip groove in the underside of the sill at the outside edge. Properly, a shallow groove - 1/8" square is enough, though I like a round-bottomed groove a little wider - is plowed about 1/4" in from the outer bottom arris/corner. This "breaks" any capillary movement of water up the bottom of the sill into the wall.
The interior finish wall in the illustration is plaster, and the sill sits on the wood ground surrounding the rough window opening. Grounds aren't much used with drywall, as far as I know, so you'd want to put a beveled support piece on the bottom of the rough opening, shimming as needed to provide good support.
If you're building windows, Pam, spend a lot of time thinking about how you'd move if you were a drop of water, and then build your window so you'd move outside.
Bill, built what feels like a lot of windows badly; finally learning a little
>"...flattening the top of the sill WHERE the stool will sit..."
>Thanks, Bill, just what I was looking for.
Andy, I looked at your book, but the window sections weren't shown in the Google copy.
Pam
>If your local library has a decent collection of older carpentry texts, you can find sections of window frames in other books. I've got, I think, some better drawings, but they're upstairs, pushed into the attic by space pressures.
If you have trouble finding good references, e-mail me, and I can dig out more pictures for you.
Look harder -- that's where I found a diagram!
VTAndy4
Thanks, will do.
Can't help myself!
Scott Burr in Ben Lomond, CA
>"This requires a pretty thick stool"
I just finished cleaning the cat box today. ROTFLMAO!!!!!!!!!!!!!!!!!!!
It's time to plant my arse on a stool and pop open a cold one.
