Waterstones - ID?
Waterstones - ID?
Waterstones - ID?
Scott in Douglassville, PA
>Hi, all -
I have some old waterstones that were gifted me years ago, and I can't for the life of me figure out which to use when. Can anyone tell in which order I should be using these?
Thanks,
Scott
Re: Waterstones - ID?
John Aniano, still reading Moxon in NJ...
>Scott,
When you find out the type of stone that is at the top of your photo, I'll also know the unknown stone I own - it was given to me by Allister Orme a few years ago when I bought some other tools from him at his home in PA. Mine looks identical to the one you posted. Maybe Allister knows what it is...
I find this water stone to be around a 200-300 grit and cuts nicely. I use it for a coarse sharpening of a few of my specialized knives where I don't want a hollow grind.
John
Ironic...
>Hi, John -
These came from Alister, too. Good to know on the coarse stone. Maybe Alister'll chime in on t'other two...
Scott
Wiley Horne--So. Calif.
>Scott,
The blue stone in the center looks to be an 'aoto' stone. An aoto is a middle stone, think 2000-3000g, and they are very useful--a favorite of mine for sure. Maybe you have a coarse, medium fine series there--duh-h-h.
How do they work?
Wiley
Some closure...
>Thanks for the info, guys. FWIW, I took all stones to some wallpaper screen to flatten and renew them, then soaked them. Going from 150 grit sandpaper through 1500 grit gives me a nice shine. Then I go to the middle stone to hone, and then the top one with some Nagura to polish. Seems to be working. The bottom stone I need to work into the protocol somewhere, but for now, I'm a sharpenin' fool... ;-)
Scott
Re: Waterstones - ID? *LINK*
Bob Demers
>The top one is definitively a natural stone, not too sure about the others, but I believed they may be.
As with all natural stones, the grading is somewhat an approximation cause the stones has inclusions and etc which alter the uniformity of the 'grade'
Check out this link on natural Japanese waterstones, to see if you can identifies yours. Now I understands that these stones portray here are probably all high grades, valuable stones, but nonetheless the colors and patterns may help you with a potential ID.
I also think that the surest way to grade theses stones of yours would be to compare the scratch patterns they leave on steel with known abrasives (sandpapers, other stones etc)
Bob, who spend the new year in paint fumes, renovating the basement that is :-)
Waterstones ID
