Kunz 53 tuning
Kunz 53 tuning
Kunz 53 tuning
Bob in Green Bay
>I just received a Kunz 53 in the mail as a Christmas gift.
I already have the Kunz 151 and have did a complete retune according to "Daves Shaves" excellent article. Things work very nice.
I would like to do the same with the 53 but thought I would query the users at large for advice before starting.
I can see smoothing the base, blade backing. I am not sure if I should attempt to take the spring loaded front base off for working it. I thought I would just punch out the pivot pins, but am afraid of damage beyond repair.
As a side note, I considered making a new blade. I tried this for the 151, but I lack the proper machine tools to cut in the height adjustment. But for the 53, the blade is simple, just a slot up the back - I think I can do that. I would use a piece of O1 steel I have (3/8") - temper myself. I am concerned the extra thickness would interfere with operation.
Down to almost 0 degrees F this morning - 3" new snow. More snow tonight. That puts us over 45" in December. You have to want to live here to like it.
Bob in Green Bay.
Re: Kunz 53 tuning
Can't help on the 53
Bill Houghton, California cold in Sebastopol, CA
>but for the 151, you might consider Lee Valley's spokeshave irons/blades - high quality stuff.
Re: Kunz 53 tuning
Re: Kunz 53 tuning
R.J. Whelan
>Bob --- 176" this season; 129" in December
RJ in Mammoth
Re: Kunz 53 tuning
Re: Kunz 53 tuning
Mike Bridger
>Bob, could you give us a link or directions to the "Daves Shaves" article you mentioned?
Thanks...
Re: Kunz 53 tuning
Just do it.
Marc in Luxembourg
>Bob,
Go on for taking off the front. Punching the pins out, take care of not losing the springs. They tend to jump where you can't find them... You have to do that, because the backing is easiest flattened on a narrow fit to width piece of MDF with wet and dry taped on it. I have done that and it worked out to be a very straightforward job.
I had a blade from R. Hock on mine. It was fantastic and there were no troubles with it.
Marc
Re: Kunz 53 tuning
Re: 3/8" seems awfully thick
Dave Mount
>I don't have a 53 so I don't know the ins and outs of its construction and operation, but with that caveat 3/8" sounds awfully thick for a spokeshave iron. Even if it doesn't interfere with function per se, it's a lot of steel to remove when you sharpen. I guess if you're hollow grinding that's not such an issue but. . .
A piece of 1/8" x 2" x 18" O-1 is about $15 (plus shipping, of course) from flatground.com. That's enough to make several, though it's no bargain if you don't need them. If you don't want to invest that much, an old lawnmower blade could be used if you've got the patience to flatten the back. You can anneal it in a bucket of sifted wood ash. The steel in lawnmower blades might be a little more of a crapshoot, but Roy uses them routinely.
Have fun,
Dave
Re: Kunz 53 tuning
Re: Kunz 53 tuning
Bob in Green Bay
>My mistake, the article was by Bob Smalser and is here in Woodcentral under articles (very bottom of the list). I included the link here.
http://www.woodcentral.com/cgi-bin/readarticle.pl?dir=smalser&file=articles_407.shtml
Also, mistake #2 - I meant 3/16" thick O1 for a new blade - that's what I have.
Re: Kunz 53 tuning
Re: Just do it.
Bob in Green Bay
>Thanks Marc! I will go boldly forward. I would like a Hock blade, and have one on a plane, but will still try to make my own here with 3/16" O1 stock I have here.
Bob
Re: Kunz 53 tuning
Bob in Green Bay
>My error. What I have is 3/16" O1 on hand.
Re: Kunz 53 tuning
Re: Kunz 53 tuning
Bob in Green Bay
>Whoa!
I used to live in Las Vegas. Drove up Neveda and Across to Mammoth a few times. Very lonely in between the places.
Enjoy the snow! I would like a bit more myself
