The Art Of Joinery {1703} Joseph Moxon
>[Lost Art Press, 2008 with commentary by Christopher Schwarz]
In the text on The use of the saw in general. S.26 on page 68-71 there is an interesting description of using a saw wrest.
If you don't have the book, the wrest is used to set two teeth at a time instead of the more common method of using the wrest to set each (alternate) tooth individually.
I have never heard of this before, and will have to give it a try as soon as I return home. Has anyone heard of this method mentioned elsewhere?
Stephen
Re: The Art Of Joinery {1703} Joseph Moxon
Warren in Lancaster, PA
>I do not have a wrest, but I have seen a Williamsburg worker use the wrest in this manner. I think it might have been harpsichord maker Hanson.
John Aniano, reading in NJ...
>Stephen,
I got my copy of the CS Moxon reprint yesterday and was reading it as you were and found the same comment about putting the wrest notches BETWEEN the teeth to add set to a saw blade. It was not the way I assumed a saw wrest was used! I, too, will have to try this...
And I think Warren is correct, at CW last January, someone there did talk briefly about this, but except for sharp-eared Warren, it may have been lost on the rest of us...
John
Adam Cherubini, NJ
>It WAS Marcus Hanson and as I recall he said it was a good way to ruin a saw blade. I think you can bend or kink the saw plate if you are not careful.
Adam
