A55 Smoothing Plane
Some really small planes...
John Aniano in central NJ...
>A few weeks ago I attended the Violin Society of America's convention in Portland, Oregon, and picked up these tiny violin makers planes. I altered them by flattening the bottoms, flipping the blade to bevel up and made wooden wedges to replace the ill-fitting metal "lever caps" and thumbscrews they came with. the bevel angles are ~35 degrees and the overall cutting angle is around 80 degrees to the base of the planes. The larger one is 18mm long and the smaller 14mm. I've used them quite a bit since then for fine details on the bows I make.
I can't take credit for making them, only modifying them to suit my needs.
Re: Some really small planes...
steve mackay
>Very nice ! Always wished I had a couple. I know if I had 'em they'd get used. Hadn't thought of flatening them though. How much material is left in the sole afterwards ? I assume theres plenty to start with.
John Aniano in NJ...
>Steve,
Maybe around 1 mm or so thick brass is left over after flattening. With a plane this small, there wasn't much curve there originally anyway. I flattened by drawing the plane over the file on the workbench. Finished with a glass plate and 320 grit paper.
I find that I use these tiny planes more like carving tools rather than flattening "agents" so who cares just how flat the soles really are...
John
Way Cool
roninkokomo
Whaooo... Thoes are real?!?
Scott Burr in Ben Lomond, CA
>Dang, how do you hold or literally use them? Then again how do you sharpen the blade?
Scott, not quite understanding these little criters.
Re: Whaooo... Thoes are real?!?
ThomD
>Sharpening them isn't a big deal I think the smallest one is 8MM, a fraction over 5/16". Easier to sharpen the plane blade than a similar sized handled chisel. LV used to sell them. I bought a set then returned, them except I was looking through my guitar tools a while back and they were there, so I guess I forgot!
They make special planes for bows as it happens. St. James Bay Tool Co sells the parts for those who want to make one.
http://www.stjamesbaytoolco.com/luthier.html
Some people use these planes with an extra long blade so it gives palm support.
One thing about these planes is people have gotten tendonitis trying to hollow violin plates with them. They are designed for tuning the plate shapes. The hollowing should be done with an adze and a serious nice big hollowing plane.
http://www.toolbazaar.co.uk/gallery/g25.htm
These are high tech, as usual the modern instinct is to improve the cut, rather than work on the removal of the wood. There is evidence excess smoothness is not required, but for those who want an adjustible mouth, of Kell sharpening jig fame:
http://www.richardkell.co.uk/luthiersPlane.html
There was a guy making really lovely sculptural bronze ones but I haven't tracked him down.
Re: Whaooo... how to hold them...
John aniano in Central NJ...
>Scott,
Your question "how do you hold them" was a real one for me. I chose to make the smallest plane's wedge with more finger holding area, i.e deeper, as you can see as compared to the "larger" plane, and it does make it easier to hold this one. I'll probably make a new wedge for the "bigger" plane.
Not much pressure is used to take a cut with these since they take tiny shavings - not much effort is needed.
As for sharpening, I find that with tools that act in a scraping mode, i.e. high bevel angle, etc., the blade need not be quite a sharp as one that takes a true shaving. I know, purists will say that a sharp edged tool is needed for good work, but with the very hard woods used in making bows, pernambuco, ironwood and ipe species, I find that the edge from a 1200 grit diamond stone often is good enough to make the scraping cuts needed. For final finishing of a bow's faceted surfaces, I do use water stones (4000 grit) or a hard Arkansas stone for edge sharpening.
John
Thanks Thom and John...
>Very interesting little beasts indeed. Still, I think I'll stick to the 100 series Stanly's.
C.R. Miller
>You're probably thinking of C. Laarman. Made some wonderful violinmakers planes a while back but I don't think he does it anymore. The ones below are some of his.
Truly stunning!
