Re: So, how come no one's mentioned this until now *LINK*
>Given that "setting it vertical" issue, having a fixed fence that requires that you move the cutter to the desired location would appear to require resetting the cutter vertically each time.
Hi Charlie
I would argue that this is unnecessary.
I mostly use scratch stocks (ala Hack). These use a fixed blade. In other words, set the blade once and that's it.
The Veritas (which arrived yesterday) indeed does not appear to have the vertical setting of the Stanley/LN #66 (I have the Stanley), but again I set the blade once, so depth of cut is not an issue, nor is the positioning against the fence. Set once and that is it.
The Veritas has a deeper fence (5/8") than the LN (3/8" - my Stanley has LN fences), and in my experience this is the more important feature for cutting a clean profile. Frankly, I would have liked to see a deeper fence, or some way of adding to the depth of the fence (which there is not), but the length of the fence (2 1/2") is a great improvement on the Stanley/LN versions (1 5/8") (see my mod in the link below).
Neither my scratch stocks nor my shopmade wooden beader have a way of setting a true vertical. I gauge this by eye. The woodie has a sliding fence, which helps a little. Eye is good enough.
If you want to reproduce a bead that has already been cut, place the blade in the cut profile and tighten the fence against the side of the board.
Improving the #66 Hand Beader
