Wracking vice...
Wracking vice...
Wracking vice...
Edward in Vancouver
>Been having problems with my vice lately, left side pulls almost 1/16" closer.
Vice is about 3 yrs old now, an eastern (China or India? I think India) Record-sorta knock-off. 13" jobbie with a "trigger" type of q. release.
So, yeah, I jam in a 3/4" scrap on the left when I hold 3/4" stock, etc. etc., but is there any way to remedy/ get rid of the wracking? Brass sleeves on the two posts or something?
Regards
Edward in Vancouver
Re: Wracking vice...
spacer *LINK*
paul womack
>tip from FWW, I think
link to discussion
Re: spacer
Edward in Vancouver
>Thanks, now I know what I can do with those scrap 1/8th" pieces....
But the vice itself? Anything I can do about that?
Re: spacer *LINK*
Paul M.
>All vices rack. There's nothing you can do about it. Be glad your's only racks about 1/16". I can easily get mine to rack by at least 1/2" without even cranking down the vice. I think I have one of the worst vices ever made (Highland hardware large face vice linked below).
I made several spacers and keep them around in my tool tray. But the one shown is a much better idea than several scraps all loosly lying around as I've been using. The "feeler guage" approach out of 1/8" scraps is on my todo list for this holiday vacation.
http://www.highlandwoodworking.com/index.asp?PageAction=VIEWPROD&ProdID=9219
Re: spacer
James Watriss
>It's a basic balance of force issue. A single screw vise pulls in the middle. Put a block of wood on the edge, and that's the source of pressure. If you pull in the middle, and have resistance on only one end, that's what happens. With a spacer, you're pulling in the middle and adding resistance on both ends, which balances things out. It'd be nice, in a perfect world, if vises were strong enough to handle crap like that, but eventually, things wear, and loosen, and that's what you get.
I've seen nifty ideas where people add a handwheel and a threaded rod to one side to use as a retractable spacer, but I personally think that would get in the way after a while. The next best idea is a twin screw vise, where the two screws hold position both forward and back. If you tighten it with a block at the end, one screw will provide tension, and the other, due to the threading, will hold the spacing on the other end of the chop.
