shootingboard question
roninkokomo
>When using either of the miter fixtures for a shooting board, how do you keep the lengths of the 4 sides of a box (or frame)what you need them to be. Looks like you could get too short pretty easily?
Re: shootingboard question
MikeW
>Hi Ron,
Always cut and shoot to accurately measured knifed lines.
Take care, Mike
Ed Mulligan, Cape Cod
>If you're cleaning up the miter surfaces, say to remove saw marks, count plane strokes and give each surface the same number of strokes. You had best number the surfaces and work them in order to make sure you don't miss one and take twice as much off another (damhikt).
If you are planing to a certain length, you can add a stop to the shooting board, or do frequent test assemblies, or both.
Ed
GolfSteve in Calgary
>Well,
You cut the first piece to the length you want.
Then you shoot the second piece a couple of shavings shorter than that.
They you go back to the first piece and make it a couple of shavings shorter the second piece.
After about 10 iterations the pieces will either be the same length or too short to use anymore.
.... :-) the simple answer is that you compare the pieces and remove any extra length from the long pieces.
Unless you are shooting for an exact dimension, all you have to do is ensure that the pieces on opposite side of the box are the same length. If you do this and cut perfect 45� angles, then you will have a square or rectangular box with no gaps at the miters :-)
yes I can see
roninkokomo
>I can see how you could turn a 10 inch square box into a 9.5 inch square box pretty easily :)
Much harder if you take a very fine cut :>)
Victor Parisian
But not impossible.
Victor Parisian
Yes, some of us persevere.
Paul Kierstead
pleasure *LINK*
paul womack
>Because a shooting board allows such accuracy, it's rather wonderful working towards a knifed line. At some point the "plane" of the shavings is passing though the 'V' left by the bevel of the marking knife.
I've never seen this so clearly away from the shooting board.
BugBear
link to discussion
Re: pleasure
Dean J in MN
>I agree -- working to knife lines is wonderful. Attached is a crosscut, note the visible knifelines around the board. This is what I see on a tenon shoulder for example, and these lines are your reference, don't remove them!
-Dean
Pam Niedermayer, Austin, TX
>Yeah, it's how my Dad used to "trim" the bushes in front of our house. We ended up with stubs. And you wonder why I don't like fiddly processes. :)
Pam
Yes
Bill Houghton, overcast Sebastopol, CA again
>True for lines along the grain, too. I love, when reducing stock to a knifed/marking-gauged thickness or width, seeing the plane hit the line - there's a paper-thin bit of wood that kind of peels off as you hit it, sending you the message that you're there.
I tend, for this reason, to hit the marking gauge pretty hard - get a good deep groove.
