Re: Left-Eyed Sawing
Bill Houghton, overcast in Sebastopol, CA
>I found out this year (at age 60) that I have the opposite problem: left-handed and right-eye dominant. Up until then, I saw myself as strongly left-oriented physically. But my saw cuts are pretty straight and clean.
The basic rule is practice, practice, practice. Hand tool skills are just that: skills, acquired through practice.
But some tricks:
The saw has an existing kerf to follow, it will. If you get your kerf started wrong, your saw will happily follow it, eager as a golden retriever, even as you try to correct it, using up a lot of your curse word allowance for the week.
Whenever possible, saw to two lines. Lay out your cutlines on both the width and the thickness of the board. Once you start your initial cut on the corner of the board, swing the saw up to near vertical while cutting down until you've established a kerf through most of the thickness of the board. Then swing it down so it's nearly flat across the width of the board and, lining it up to your layout line, cut gently until you've established a long, shallow kerf across several inches of width. Now, gently bring the saw up to use these two kerfs to establish a kerf that's both vertical and aligned with your intended crosscut. You may have to repeat this several times as you go, and, if you see the cut going off course, return to holding the saw low.
For cuts that have to be carefully aligned, it's better to cut a bit on the waste side and clean it up (search the messages for "shooting board" for some discussion of how to clean it up) than to try to make the cut perfect.
Get your stance right. You want the motion of your arm to be kind of like a steam engine's driving rod - straight and aligned with the cut, with your shoulder and hand aligned with the cut. You also want the height - the relationship of your body to the wood and the saw - to be right. Saw horses or saw benches, for big crosscuts, are better than the top of your workbench.
Don't rush it. The weight of the saw should be enough to make the cut; your job as sawyer is to guide it. If you find you're gripping the saw handle tightly, or pushing too hard, you'll cut badly. Your motion should be about as vigorous as you would use in, say, throwing a ball to a three-year-old (well, maybe a little more; but not much); if you feel like you're in the finals of your bowling league, lighten up.
Sight the length of the saw. Is it straight? If not, this could be part of your problem (although some of the saws I use regularly have a slight curve over their length. this is not ideal, though).
If all this is working well, and the saw's still going off course, it may well be sharpened or set wrong. Don't do this next step until you're convinced that it's not you, it's the saw: take a sharpening stone and run it gently along the side of the saw teeth on the side toward which the saw is cutting. Try it again, and see if it helps.
But, again, the key is practice, which includes a patient understanding that you won't be as good at first as you are later.
All this took longer to write than it would have to have shown you; that is, of course, the unfortunate part of the Internet. So, if you're still having trouble, seek out an old dude/gal in your neighborhood who knows how to use a saw and ask him/her to show you.
