Old Yardstick? Not Quite!
tek,brunswick
>I was cleaning out a closet while preparing My MIL's house for sale. In it was a rusty yardstick. I decided to clean it up and found out it is a Lufkin # 95 circumference rule.
tek,brunswick
closer
tek,brunswick
Back
tek,brunswick
Nice
Bill Houghton, overcast in Sebastopol, CA
>I've got one of those, too, though not as clean as yours. I tested it against my shorter machinist's rules, and it's accurate.
I worked briefly in sheet metal, and never saw one of these then - but it's clearly designed for sheet metal workers. The tables on the back are a quite interesting illustration of what shapes were important then, and how important it was, when building a container for someone, to build it to meet accurate measures - before it became an odd concept that you would have someone build you a container, rather than going to Target to buy one molded from plastic.
I find a three-foot rule quite helpful at times, and imagine you will too.
WOW ! Thats a keeper !
steve mackay
Tables
tek,brunswick
>It took a lot of work to get it that clean! I liked the tables also. My FIL was a welder. He worked for the gas company and after that he joined the plumbers union and welded pipe at power plants and steel mills. He said he could weld anything from a broken heart to the "crack of dawn" if you could find him the right rod.He probably used the circumference scale more than anything else. He passed away more than 10 years ago, so I can't ask him if he found it useful. I do some woodturning so I think I may find the circumference scale handy myself. It was fun discovering I had something better than a yardstick. A lot of the rule was not legible until I cleaned it up. I hope you enjoy your also.
Tom
