200+ woodworking book reviews
Tote for #2
Tote for #2
Tote for #2
tek,brunswick
>My Father gave me a Stanley #2C The Tote is cracked. Are there replacements available? I see most of the after market totes are for #3's or larger. If I decide to make a replacement Tote what kind of rosewood is closest to original and what do I use for a finish? I was going to use the plane in the shop. Does it have more value as a user or is that model a collectors piece?
Re: Tote for #2
Chck yr. email
Wiley Horne--So. Calif.
Re: Tote for #2
Fix it? *LINK*
Sandor in Middletown, DE
>If you have all the pieces, why not repair it? Check the link.
I like the idea of keeping original parts with the plane, unless of course it is broken past the point of no return.
Good luck.
Fixing a Tote
Re: Tote for #2
Re: Tote for #2 *LINK*
Bill Houghton, sorta sunny in Sebastopol, CA
>If the crack is clean - no missing wood, no major bruising - and in a location that's amenable to clamping, you may be able to reglue it. I'd try that first.
Others have suggested that the rosewood on these totes is an oily wood that requires special prep and glues. I've used regular yellow glue with no prep other than dusting out the spiders, with great results; but I can't speak for your tote (maybe the wood on the planes I glued wasn't rosewood, though it was dark and pretty).
The cracked totes I've encountered have been cracked about halfway down, where the palm of your hand centers. If this is true for yours, it's not too hard to clamp.
The tote's an awkward shape, and, at first, it appeared to me it was unclampable, but I've found that those trigger-type bar clamps with the plastic heads will grip and flex enough to work. I've linked below to the listing by one of Wood Central's sponsors, but these clamps (lots of different makers) can be found in any hardware store or home center.
I can't speak to the collector vs. user value. My hands are large, so I'm not sure I'd find a No. 2 a useful tool, but others have testified to their usefulness for small work and cleaning up small areas. If your dad gave it to you, and it's been in the family, in my opinion, it's worth more than money; and using it will honor it.
If the top of the "horn" is broken - another common ailment - perhaps the best method is to clean it off - remove and plane smooth, if you have another plane; remove and file/sand smooth, if you don't - glue on another piece of wood, and rasp/file/sand it to shape. The broken handle has already lost its collectible value, so patching it will make the tool more useful without reducing value.
I just checked, and it seems others have proposed fixing it, although I suspect Wiley Horne's offering you a replacement, sly dog. I hope this information will help.
Woodcraft's listing.
Re: Tote for #2
plane pic
tek,brunswick
>Here is the Plane
Re: Tote for #2
Plane sole
tek,brunswick
Re: Tote for #2
#2 Front
tek,brunswick
Re: Tote for #2
Re: Tote for #2
R.J. Whelan
>Tek ... No 2's are pretty valuable and I think the 2C's are even more rare.
As others have suggested I would attempt to repair the original tote first. Failing an acceptable repair I would make a new one from whatever species that most closely matches the original and definitely save the original for future generations.
I have large hands, so I made new totes for almost all of my metal planes (even the Lie-Nielsens) - I recently sold several planes and I'm sure the price would have suffered had I not reinstalled the original totes and knobs.
As to finish: I have always favored several applications of oil followed by wax. I actually soak the totes and knobs in a jar of tung oil for several hours (first application) and then keep applying addition until it won't absorb any more.
Good luck with your repair and congratulations on the new addtion to your shop ............. rj
Re: Tote for #2
Re: Tote for #2
Bob Demers
>Years ago I acquired a Bedrock 602 without a rear tote. After trying unsuccessfully to get one on da'Bay, I finally purchased a new one from an Ebay dealer called miss_claudie( 1506)
Im happy with my purchase, came complete with a new bolt and brass hardware. I had to slighly sanded shorter my brass screw to fit correctly, but other than that it was a great fit.
Had a quick peek on Da'bay and she does not seems to have anything to sell right now, nor do I know if she still sell them.
Another vendor I know of was 'Mike in katy' not sure if he is still active neither.
Yes, there are old original ones that pop up for sale on Ebay here and there but they quickly go up, and I always got snipped on them, hence why I went with a repro.
Yours look like it could easily be repaired as explained earlier by another poster.
Bob, who quite enjoy his beloved 602
Re: Tote for #2
Nice plane Tek...
Scott Burr in Ben Lomond, CA
>A 2C is a valuable plane. I don't know about today's economy but their were selling for $300.00+ on ebay a bit ago.
I have one and it's a nice little smoother.
As said, try fixing the tote first.
Re: Tote for #2
Thanks to all
tek,brunswick
>I'm going to try to fix the original tote. Does anyone know what the original finish on it was? If I were to make a new one does anyone know which of the many rosewood varieties was used in the original tote?
Thanks
Tom
Re: Tote for #2
Re: Tote for #2
Ernie Miller
>I think I have a #2 nailed to my bench as a drawer pull? might be a #1 have to check that. but the tote I am sure was a reworked #3 tote if all else fails you may try that. If I remember corectly the horn is a little shorter than normal because of that.
