How to make a chisel ( of similar lathe tool)
Bill Tindall, E.TN
This post is in response to two people that wanted to make custom shaped chisels but were stymied by not knowing a way to fabricate them. My only claim is that you can easily and cheaply make a chisel this way. It will work as proven by those I have made that have worked for me. As most of you should know, I make stuff. In making stuff, I have used these chisels exclusively since the days of Badger Pond when I first made them. I have cut hundreds of dovetails with them as that was the application they were designed for. You can bash on them with considerable force with no adverse effects, proving that traditional bolsters are not necessary. In fact I have beat the crap out of one seating its handle (before I found a better way) and it held up fine (I have underway a set of longer paring chisels that are going to look like Dave's as I suspect he makes his chisels the same way that these are made, but with less robust steel, in my opinion).
It is less effort to make a new chisel than restore an old one with pits in the blade.
I am not claiming you can sell them, nor that they are pretty or that my shape is best for your needs, so spare me these criticisms. (When we first posted how to make a chisel or lathe tool years ago on Badger Pond I got all manner of unjustified and uninformed critique and I am still a bit prickly from the experience)
This design will evoke the same controversy that rages in the knife community between forgers and cutters. Spare me this criticism as my only claim is for a chisel that works, for those that aren't wedded to how it came to be- from hammer or hack saw.
You will need a source of annealed(soft) steel. O-1 is a good choice, far better than A2. It is available in any thickness from anywhere that sells to machine shops, or from a local machine shop, or knife maker. A hack saw and a file are sufficient tools. Obviously machine shop tools will make the tasks faster and the tools prettier. The tools can be heat treated by hundreds of places across the land. Ask knife makers or machine shops where to get stuff heat treated. It is very cheap and not worth the effort to do it yourself unless you already know how. Or have a knife maker or machine shop cut them out for you.
The picture shows an old commercial chisel to illustrate that I am not a nut-case with some wacko design that won't work because that isn't what Witherby did 100 years ago. It is made just like my chisels shown below it. The bottom chisel shows how to cut the steel. It is important to have the tang straight sided.
1. Cut a piece of steel to width and length. Annealed tools steel cuts easily, especially so CPM 3V. .
2. Cut the tang. Round the inside corners to eliminate heat treat stress. A chain saw file works nicely.
3. File/grind/sand the edges smooth and flat, or beveled, as you wish.
4. Grind the bevel approximately how you want it, eg 30 degrees, but don't make it sharp before heat treating.
5. Send out for heat treating and tell them it needs to be flat. A skilled operation will ensure it will come back flat. We use Mid South Metallurgical 615- 896- 6212 I would heat treat O-1 at Rc 58-60. Actually, I have never used O-1 so this hardness is an educated guess. A harder heat treat will make a stiffer, but less chip resistant blade.
7. After heat treating, flatten back and grind bevel to final angle. This operation is easier before the handle goes on.
6. Turn the handle, or buy one. Bore it exactly or slightly less than the width that the tang is wide. Install the ferrule made from brass pipe, copper tubing, hydraulic hose ferrules, etc. Bash the handle onto the blade affixed in a vice. If you did what I recommended the blade will self align in the handle hole. Smear in some epoxy and drive in split dowels to take up the space on each side of the blade.
Note: there are other ways to install handles but this way is easiest to insure the handle comes out straight.
Note: lathe tools can, and are, made the same way.
