Re: Questions on Dai making
ThomD
>"That blade take an incredible edge and hold it has well. Currently it has a few nicks at the edge so its due for a good workout on my Japanese waterstones (King)+ natural Nagura stone. Currently the blade cannot sit low enough to cut and seems to stick mostly on the sides of the abutments."
Baiscaly what you describe is the condition of a new plane that hasn't been used (wether or not that is the actual case here). They often come too tight to the sides, and not low enough, so really you are where you need to be to get to where you need to go.
The first thing you want to look at is whether if the blade is lowered in this dai, would it have clearance at the edge to take a full width shaving (another issue that is often out of wack on new planes and left to individual preference). You can discern this by comparing the width of the available edge of the blade to the width between the abutments on the sole of the plane. Because the plane blade is held by it's edges it has to be docked a little on the corners or the full width cutting edge would try to cut wood that would not be able to clear through the abutments. The solution is to enlarge the grinds at the corners of the blade edge, or potentially narrow the abutments if there is any reason to believe they are too deep and cover too much of the blade.
Once the width is sorted. You probably want to relieve the width of the plane mortise so that hammering in the blade does not split the dai. Remove a judicious amount of material, first measuring the width of the blade if fully sunk, and project those lines top and bottom. Then score the body with a saw and remove the waste with a narrow chisel, etc...
Finally you can pencil the back of the blade so that when inserted it will leave a mark on high points of the dai, and work those down by paring, scraping, or use of a float. Proceed carefully, and remember the Japanese plane is designed to hold the blade under force. You want it to be virtually impossible to overdrive, of course it is possible, but you want to work for a tight fit that is even across the blade, and that naturally returns to battery every time you re-insert the blade and tap it firmly in place. It's a precision tool that should not require brute force to use, but neither should the blade be too easily inserted. Also the blade may find it's place, a little lower, as it is used for the first while, so don't baby it.
The fitting is easy, just proceed slowly.
I don't care what angle you have and what angle you want, you will find this plane cuts everything really well if just seen through to a proper condition. Then you can consider other beddings. As you like.
One minor point is that the back of the blade is usually transverse concave, so that is how the bedding will come out in the plane.
Another minor point is that some planes have a secondary bevel in the bed that supports the bevel of the blade. This is an added complication I will leave unless asked.
