Made a screw
Made a screw
scott grandstaff
Made a screw
scott grandstaff
>Today I had a good day. I made a screw!
It is a lever cap screw. Not a terribly big one. :-)
http://users.snowcrest.net/kitty/sgrandstaff/images/hometools/leverscrew2.jpg
Yes, that is paua abalone shell inlay
http://users.snowcrest.net/kitty/sgrandstaff/images/hometools/leverscrew1.jpg
So, I have a question. A design question.
I have a small genuine ruby I can inlay into the center of the shell.
The shell is dark clear blue with sparkling irridescent highlights you can't see in the pic.
I'll go with a lighter to mid colored ruby or it would look black, I think.
Think I should?
No holds barred? Damn the torpedos?
or
Is enough enough already?
yours Scott
Re: Made a screw
scott grandstaff
Made a screw deux
scott grandstaff
>Well DOH! I could have sent the pic instead of making you copy and paste the link.
Sorry
yours again
Scott
Re: Made a screw
Re: Made a screw
Alan DuBoff
>Scott,
Looks excellent as-is, IMO.
But come on, let the cat out of the bag, what's this screw going on? :-)
Regards,
Alan
Re: Made a screw
Re: Made a screw
ThomD
>I think you have lost your bearings already... :)
Anyway, for me it would depend a little on two things, design wise if you want the focal point to have a focal point, then I would look specifically at the pearl as to whether it is really nice stuff and centers the eye, or is a little blah or moves the eye odd center due to some pattern in it. If it is doing it's job all well and good, if not then you consider the ruby.
Consider the way the colours will work together, are they appropriate in the same setting
Also personally a real ruby is a little sweet for my taste in a MOP setting. You have to have your own feel for all this stuff.
I assume the ruby isn't actually a ruby, but a piece of glass. I assume the MOP is real MOP. So you have an integrity issue also. You can't improve on MOP, it's real, there is no better material on earth. There are rarer and more precious ones but nothing higher in origin. One can compare a piece of walnut to a diamond, but how does one compare a piece of walnut to faux plastic walnut veneered MDF? So assuming you have real MOP and faux ruby, I think that draws down a piece to insert a glass ruby. If it is real ruby, then it is just a design question.
Did you really make that screw? Or did you insert it through the hole you are now covering up? It just looked a little dissimilar in metals in the one photo one can see it in. Someone needs an engine lathe for Xmas?
Re: Made a screw
Yep
Wiley Horne--So. Calif.
>We need to know what the screw is screwed into. Photos please!
Wiley
Re: Made a screw
scott grandstaff
Made a screw deux
scott grandstaff
>Don't worry guys. I'll post a pic of the finished plane. Soon as its finished.
It's going to be cute, I hope............
As far as materials, of course its real pau abalone and if I do mount one, it'd be a geniune mined and cut ruby.
No need for fakes. Its the size of a pencil eraser! Not the crown jewels. You can have anything, as long as its small.
heh
Its definitely a 2 part screw though. I like steel threads for longevity better than brass, especially in this small size (one bump and brass is gone), but the head wants to be decorative.
Its tapped in and silver soldered.
yours Scott
Re: Made a screw
Re: Made a screw deux
ThomD
>With all real materials you can best judge the wow factor you are after.
Just trying to score you a lathe for Xmas, if you don't already have one.
Can't wait to see the end result.
Re: Made a screw
Way too nice to change...
Scott Burr in Ben Lomond, CA
>Hi Scott,
I'd leave it alone. Nuff said.
This Scott wondering why Thom is riding your arse...
