Diamond sharpening
Diamond sharpening
Diamond sharpening
ThomD
>I tried out my new found piece of cast iron with some 1 micron paste. I used a half drop on the 8"x2" plate, and it spread far and wide. Cutting action was fast and I fairly quickly got a sharp edge on a 5/8" O1 chisel. So far so good. The paste had loaded up though, and would not work on chisel two, so I flushed the surface of the plate with WD40, gently, hoping to carry off mud and leave diamonds. As far as I can tell, I don't have any diamond paste left, or not enough to do further sharpening. What should I have done?
The other odd bit was that water seemed to form on the plate as I was sharpening. It could just have been condensation from the atmosphere, though it did not occur on the underside of the plate, as far as I could tell, and the droplets sorta looked squeezed out of the paste...
I found the process a little messier than I like, sandpaper still leads on that count.
Re: Diamond sharpening
Bill Tindall, E.TN
>I used a half drop on the 8"x2" plate, and it spread far and wide............... Not sure what a half drop of paste would be as paste doesn't drop. Is it oil based paste and in a syringe? If so start with 1/2 cm or less "worm" of paste and spread it around. You will need to add drops of WD 40 or some other lube (mineral spirits for example) to wash away the grunge that forms. For a simple honing I just wipe it up at the end with a paper towel, or for serious grinding it can be floated off the edges with a paper towel under the plate. In use, I treat the plate like an oil stone as far as lube goes.
The paste had loaded up though............need to add lube to prevent the plate from getting sticky while honing. The fact that it got sticky means you are removing metal (good).
. As far as I can tell, I don't have any diamond paste left, or not enough to do further sharpening................... I don't understand this part. Once the diamonds embed nothing will unbed them , certainly not simple washing. And they don't wear out very quickly. It may take a few uses to get the plate loaded uniformly. On a used plate I sharpen many times before renewing a charge.
If the water observed was not condensation on a cold plate, I'm mystified as to the source.
I recharge the plate often
Steve Elliott
>I've found that the speed of honing is so much better with a fresh charge of diamond paste that I usually add a little each time I wipe off the plate. By "a little" I mean just a smudge that only covers half the plate when I spread it out as thin as possible with my finger. That very small amount is usually enough for honing one plane blade. After each blade I wipe the black slurry off the plate and add a little more paste, or just wipe the plate with mineral spirits and put it away.
I'm still using my first syringe of 1 micron paste and have sent some of it to others to try out. The per-blade cost of the paste is very low, no more expensive than sandpaper or waterstones.
ThomD
>I think the basic problem was not enough paste to start with. I added more, which seemed unecesarry since the first application seemed to cover, but it evidently got lost. It is now working OK, I will have to keep monitoring it to see how it holds up.
Thanks for the coments.
