Combo square ID and related questions
Bill Houghton, sorta sunny in Sebastopol, CA
>I'm assembling a combo square from bits. The square/miter head pictured below has a pretty well identical pattern to a center head that's got the distinctive Starrett clamp nut on it. Since the center head's clamp bolt is captured, I am currently thinking that it's a Starrett, and that this is a Starrett head too. The current catalog doesn't show this pattern. Can anyone confirm that this is a Starrett head? Is there a way to determine whether it's cast iron (which seems likely) or steel, without grinding a corner off?
Re: Combo square ID and related questions
And question #2 is
>This clamp bolt, which came in another, similar combo square head (same surface texture, more rust), won't tighten up in the head pictured in my lead message, because the little nit sticking out on the left side just below the half-round section won't go into the hole. What's the purpose of this little nit on a combo square head (I understand that, for a center head, it serves to capture the clamp bolt/nut)? Is it there to keep the clamp bolt from turning? What's the best way for me to proceed? File out a slot in the head's hole to accommodate the little nit, or file it off the clamp bolt?
Bob Demers
>well Bill
it look Starret allright but the bits of metal webbing (flashing?) left here and there in the opennings, does not look like something Starret would left out the door.
I'll say its more like a generic version of a Starret, not the genuine article.
Of course I could be wrong, it happens sometimes :-)
Bob
That might explain why it's not quite square
>correcting square is to be one of the tasks in assembling this square.
