Re: Shellac: made from flakes vs. premixed?
Wiley Horne--So. Calif.
>Hi Wilbur,
Here's what I like about dewaxed flake shellac....Dewaxed is more water resistant than waxed. Jeff Jewitt did testing several years ago and dewaxed shellac was competitive with lacquer for water resistance--not as good as lacquer, but close. Shellac containing wax, including bullseye, will be less water resistant than dewaxed.
Flake does not degrade. Does not esterify in solution, because it's not in solution. I mix up small batches in quart rubbermaid containers that I get from wally world, and the dry flakes which are still in the bag or can remain dry and maintain their potency. Fresh shellac dries quickly and is harder than shellac that's getting played out in the can--maybe Zinnser has solved this, but find out.
You want to be able to control the cut. If you can do that with Zinser, fine. But you need to be able to control the cut. For example, you may want to use your shellac as a resist coat over water soluble dye, like transtint for example. If you want to completely seal the pores at that stage, you might use a 2-lb cut. But if you want to only partially fill the pores, you might use a 1/2 lb to 1 lb cut. What I think is really a nice finish interior to case goods or drawers is a real thin cut of shellac--Krenov described this in one of his books. Use 1/4 lb to 1/2 lb. It imparts a sweet and pleasing smell (that lasts forever near as I can tell) and equalizes (to some extent) differential moisture uptake.
When it is dry and warm, shellac will dry very quickly. You get one wipe of it, at most two, and that's it. It's helpful to use a thin cut on days like that, because you get that second wipe before it dries. Plus you don't get a 'fat edge', which is just murder to try to straighten out, and which will happen if you use a 3-lb cut on a dry warm day (out here anyway).
Compatibility. If shellac is the final finish, then this doesn't apply....But, suppose you're coming in behind a seal coat of shellac with something else. If the shellac is dewaxed, it will be compatible with everything else. Everything will adhere to it. But if the shellac has wax, you have to make sure that the top finish coat will adhere. Polyurethane and polyacrylic won't. That's not a deal killer maybe, because maybe you don't use those--but my point is that you have to slow down what you're doing and find out. Whereas if the shellac is dewaxed, you can proceed without worry.
The end.
Wiley
