Gloat
Gloat
Gloat
ThomD
>I'm not sure whether gloats are banned, or just bad maners, here goes anyway.
This stuff is all hand tools though it is mostly not woodworking. I went to a machine restorer today to get a much coveted Mill table. They are great for fixtures and welding and so forth, and I will use it for bike frames. It is a dead flat table with fixture potential, so it could even be used for critical planing.
I managed to snag a piece of hand scraped cast iron for my diamond lap. It was used as some kind of davetail ways gage, so it's probably pure to the tens, or something ridiculous. I also got a buch of really pure rules for restoring machines and such. My name is in for the metal scrapers when the place finaly closes down.
The pic is poor because I'm not taking the stuff out of the truck until the rain stops. There is one of the large rules visible, spotted with machinist's blue, and the little chunk of pure cast iron for my lap (free).
Re: Gloat
Re: Gloat
Bill Houghton, moderately nice in Sebastopol, CA
>Thom,
You [fill in verb from charades photo below].
Machinist and related stuff can sure be helpful at times. One of the items I got from my dad's garage was a jig used to check that connecting rods were square. Not a very useful item anymore, but there's a 12" long by 4" wide chunk of cast iron on it that I speculate is flat to high tolerances, waiting for me to reach the point on my list that I explore diamond sharpening. Maybe I should invite you out to a visit to California's wine country (we're the real thing, not like those wineries in the Napa Valley just east of us that CHARGE in the tasting rooms!), bringing one of those straight edges with you to check it.
Re: Gloat
Re: Gloat
Wiley Horne--So. Calif.
>Thom,
Super finds! Truly a gloatworthy gloat. Gloats are good. They spur us to go forth and make our own Christmas luck. I've never heard of a 'mill table'--how wide? how long?
That lap is the very thing. I would suggest proceed cautiously if you use it for Japanese steel. For me, I can use fine mesh (1/4, 1/2 u) on superblue steel, which is alloyed, but I've ragged a couple of real hard white steel blades. Your mileage may vary, but I caution just in case.
Thanks for sharing!
Wiley
Re: Gloat
Re: Gloat
ThomD
>Indeed I do Bill, there was a great sucking sound as precision milling paraphernalia was suctioned into the box of my truck! With current baggage limits I'm not sure I could get one of those straight edges on-board for California, might have to rent another seat on the plane.
Willey, the mill table was off some milling machine that was at one time a project of someone's, now destined for scrap. It is about 48 inches long, and 8-10 inches wide. It's a fairly precise surface that one can attach just about anything to. For legs I have a nice pair off a Seneca lathe. Bicycle jigs cost about 1-10K, but from another perspective, frames are just a collection of tubes and can be fixtured conventionally with a little help. So I hope this will serve me in that regard. This link shows a version of what I need on the cheap, though no mill table. Anvilbikes.com shows how you can part with some serious coin.
Willey are you saying the diamonds, gouge up some Japanese tools? I will be careful. I have admit that I have my woodworking tool sharpening pretty much nailed, I was hoping this would speed up honing HSS tools. But I assumed it might well work well on just about anything else, so thanks for the heads up. In fact for the cold weather season, alternatives to water stones and such are something I hope for.
Re: Gloat
Re: Gloat
>Thom,
You make custom bikes?
The diamond is perfect for HSS such as M2--I use it down to 1/4u for that and it will put a real edge on M2. Don't let anyone tell you it won't get sharp. Diamond is great for all high alloy--Bill T. has talked about particle 3V (not a HSS if I recall correctly), to which I would add Hitachi superblue steel.
Diamond will also work just fine with A2 or O1.
The problem I have had is diamond versus RC64ish white steel, non-alloy straight high carbon steel. You could try it. My problems involved coarser mesh diamond, where I was trying to rebevel to a lower angle, and this steel is not far from martensite. I worked the new bevel down to the edge, and then the diamond Just tore the edge up and left it raggedly serrated. Had to sharpen 1/64" or so off of it (with water stones) to remove the ragging. It may be that superfine diamond would work OK on it, but I'm going to stick with natural stones, because my tentative conclusion was that diamond is too hard for RC64 straight carbon steel.
My suggestion is give it a try on Japanese chisels, because maybe I was just doing something uniquely dumb. But check as you go.
Wiley
Re: Gloat
Re: Gloat
ThomD
>I am making bikes and stuff for them. Been gradually increasing my metal working content. Expensive to break into, but I'm gradually getting there. As much as a I love woodworking I get a better payout making things in metal. A small part can save me a lot more money than most of the stuff I make in wood, though since I rarely if ever buy furniture, I probably under rate that cost.
I notice I left out the upright jig link:
http://ca.youtube.com/watch?v=k9JG12MdQVE&feature=related
