To Rob: New DT saw teeth?
Alexander Grigoriev
>I understand that the teeth of the new Veritas dovetail saw are not induction hardened. Have you considered doing that? I'm afraid it would dull too fast without it on harder wood, and not everybody feels confident enough to resharpen a saw.
Supposedly, hardened teeth would make it more difficult to resharpen it with a file (or impossible to resharpen at all? is it possible to set the teeth?).
Re: To Rob: New DT saw teeth?
MikeW
>Induction hardening of the teeth would make it a throw-away saw. Induction hardened teeth can snap when reset depending on how far past the bottom of the gullet the hardening occurs--Rob's saw can be reset when needed (after a few sharpenings) for the life of the saw. Which seeing how I have some saws nearly as old as the US...
The teeth will remain sharp for quite some time. With *very* little practice, anyone can learn to sharpen a saw adequately.
fwiw, I have used the same DT saw for sawing kerfs in the Bubinga handled saws LV carries for a year without resharpening. Way longer of a cut than DTs are typically cut in a board, twice or thrice as deeply. They do remain working sharp in hard woods for quite some time.
Take care, Mike
not Rob today nor any other day...
Rob Lee
>Hi Alexander -
Mike's quick off the mark! (he must have lunch before I do...).
We were after a resharpenable saw here - so there was no plane to do induction hardening.
Same reason we looked at a 14TPI vs something like a 20 or more TPI - aside from being a good all-round size, we want you to be able to sharpen it relatively easily!
Cheers -
Rob
Thanks, Rob, I'm getting one!
Alexander Grigoriev
MikeW
>Ha...haven't made it to the shop yet. Running numbers, designing stuff, spending money on-line. I can do those things from the comfort of my home on this Thanksgiving day in the US.
But I do need to go in for a couple hours. Need to figure out how I am going to raise the new mill (a bit less than 1000 lb) onto the stand.
Take care, Mike
Will sharpener (02K08.01) work for it
Alexander Grigoriev
>The description says it works for up to 12 tpi only.
Re: Will sharpener (02K08.01) work for it
Brent Smith, Montreal
>Hi Alexander,
Rob, or Mike, will probably chime in, and possibly correct me, but...I just checked my saw against my files and this is the one I would use to sharpen this saw.
Wiley Horne--So. Calif.
>Mike,
"Need to figure out how I am going to raise the new mill (a bit less than 1000 lb) onto the stand."
I won't give you the advice about "don't bend your back, lift with the legs".
Seriously, can you get a portable gantry crane into position? Or is it cramped quarters? Maybe you know someone who has one. Everything I can think of jerry-rigged has disaster lurking not far.
Wiley
Missed Link *LINK*
>62W12.05, $" extra slim.
4" File
MikeW
>Hello Brent and Alexander,
Brent is correct. That size file is what we use on 14 - 16 ppi saws.
The hand saw sharpening guide that Alexander linked to will not work well--wrong size file. But more importantly, such guides are actually a hinderance.
Take care, Mike
MikeW
>Hey Wiley--Happy T-day!
Yes, I just got back a bit ago. We'll either rent a gantry crane or a manual lift. The gantry will simplify lifting and moving over the base cabinet.
Right now it is living upon the pallet jack, looking sad it is not being used.
Take care, Mike
Marv....... Northern California Lake Co.
>Hi Mike,
I had to do exactly what you are having to do to raise your mill up onto it's stand. I don't have a forklift or any mechanical means of raising something that heavy. I did it by myself using lots of wood blocks until I got it high enough to roll it onto the stand using short pieces of pipe for rollers. I has to be kind of a mood thing and the right attitude and take you time and not be in a hurry. Two people could do it in half the time though.
I have moved my mill three times this way.
Marv
Engine hoist
David Cockey
>Engine hoist - one of the roll around type which folds for storage. Usually rated fro 1000 lbs with the boom fully extended and 2000 lbs with it pulled back. All seem to be made in China these days but if you look around you can find one which is adequate. Ours is one of my wife's favourite tools. Used to put the planer on it's stand.
hack style
paul womack
>the gadget in question
I REALLY do not like that jig; it gets in the way of any "natural" interaction with the file, and makes it quite difficult to move from tooth to tooth.
(I found one at a car boot, and have used it).
Further, it requires special files that aren't available in all sizes.
The techniques I do recommend are on my webpage, so I won't repeat them here, I'll just link.
my saw sharpening info
I am, BTW, quite a big fan of jigs, aids, and guides; I just don't think this is a good one.
BugBear
