live edge lumber
live edge lumber
live edge lumber
Howard Pollack
>Hi- I have a slab of kiln dried live edge lumber with the bark still on it. I'd like to make a mantle shelf out of it with the bark removed and the remaining natural edge retained (like Nakashima). Does anyone have any ideas about how to handle this other than carefully pulling and scraping the bark off? Is there a particularly good way to retain the remaining edge? Thanks -Howard
Re: live edge lumber
ThomD
>Bark comes off depending on the time of year it is harvested. It either just falls off or you do have to remove it bit by bit. It's possible that some steam or soaking in water would help. Th eonly other thing I would try is snad blasting. I bought one of those cheap SB attachments, but I haven't tried it.
Once the edge is clean there isn't anything special you need to do to preserve it. It's just regular wood. I;ve turned tons of natural edge bowls and they are perfectly durable. Getting the bark off is the best first step since it holds moisture and so forth. Though solid bark edges will hold up for years. The only thing about natural edges is that depending on how tangent or radial the board is, and other factors, they can be pretty dangerously sharp.
"Snad blasting"? I love typos!
Hank Knight
Options after removing the bark
>The cambium layer, just under the bark, often appears as a thin brown membrane on the surface of the live edge. Depending on the appearance you're after, you might decide to clean this off, which you might try with Scotch-Brite if you don't want to remove any sapwood tissue. If the edge is irregular or prickly, you might want to use a spokeshave or rasps to make it flow more smoothly. This is often desirable for edges that will be in contact with people, such as the edge of a dining table or coffee table.
Ellis Walentine, Host
>It depends on the tree, what type of tree is the lumber from? If it is Hickory it will not fall off in your lifetime, nor that of every future generation.
Bark can also contain a lot of sand and grit that can ruin an edge tool. If you have a barking spud, a large flat chisel like tool with a long handle, they work.
You can use a drawknife if you have one. You can also pound on the bark with a round stick like a baseball bat, hit it directly across the grain, sometimes this will loosen the bark allowing it to be stripped easily.
Good luck.
Stephen
Could be worse...
wilbur
>...it could have read "nads blasting".
Ouch!
R.J. Whelan
>Howard ... you didn't mention the species but I have had luck with the following sequence of attack:
1. Beat on the bark with a dowel or pipe
2. Remove all loose bark
3. Wire wheel in a drill motor
4. Flap sander in a drill motor
5. Hand sand
Good luck ... rj
Omar was right
Hank Knight
>That's funny!
Omar was right:
The moving finger types, and having typed, moves on.
Nor all your piety nor wit can lure it back to cancel half a line.
Nor all your tears wash out a word of it.
