Appreciating the old layout tools
Bill Houghton, sunny in Sebastopol, CA
>For years, when I've needed to lay out a 45 degree line, I've used my combination square. This gets tricky sometimes when working at the end of a piece of stock.
Several years ago, I picked up a Stanley miter square at an estate sale, using Sir Edmund Hillary's Everest-climbing excuse*. Until today, I hadn't used it.
Today, I needed to hand cut some miters on 3/4" by 1/4" screen molding, and the combo square was just too awkward: I was working at the end of the stock, so I had nothing to butt the square's head against, and I was going to have to run a line up inside the rule anyway, where it's hard to reach. Then I remembered the miter square. What a revelation! I could hold it easily along the length of the stock, down away from the end, and mark anywhere without having to squinch the pencil into a restricted area.
To fellow rust-hunters: if you see one of these at a garage sale, jump on it. It is NOT an obsolete tool since replaced by the combination square.
*For those not familiar with his response when asked why he climbed Everest, he is reputed to have said, "Because it was there."
Re: Appreciating the old layout tools
Tony Zaffuto
>Feeling a bit contrary today: if you see a recent English manufactured similar plane, made with rosewood and blue steel, don't buy it. It's mine and the steel blade is not parallel! Won't mention the maker's name, but it is not a very costly tool, but with the blade, it is basically useless, unless you remember which side to use, each and every time.
Might be a tool I give to some deserving tool borrower sometime :).
T.Z.
Nice tool ! . . .
steve mackay
>I'm holding out to spot a Lufkin cheap !
Kevin French, Antrim, NH------WebKitFormBoundary3x
>Bill you gotta Love finding a tools Twice, especially when the second time it's in your collection.
Something I do regularly
>Which I think is a bad sign that I own too much, unless it's a bad sign about my...oh, shoot, what's that word? starts with M...oh, yes, memory!
