Granite Question?
Granite Question?
Granite Question?
Monty Bates
>Normally I just lurk here reading and learning but now I have a question. Yesterday my wife and I went looking at Granite Countertops. Talk about sticker shock when it comes to price!! At any rate while we were out back looking at full slabs of Granite I noticed this hugh pile of small size cutoffs. Most about one square foot or a little less. My question is would these be suitable for using with diamond paste instead of a lapping plate? They are free in any color that suits you at about an inch and a quarter thick.
Re: Granite Question?
Generally not...
John in NM
>Though hard and flat, diamond doesn't embed in stone as readily as it does in iron, copper, or wood. So it will work, but will need frequent re-charging. It would be interesting to try it with Silestone and similar products though, as the epoxy matrix might pick up diamond and hold it.
Christopher Fitch @ Memphis
>Well the answer is ... it really depends on how flat the pieces are. You certainly can use a granite plate for lapping though I'm not sure about how diamond paste would work.
If the pieces are not cut flat enough, it might not work for you. After all these are countertop pieces, not machinist grade granite plates used as precision reference. I have no idea if they are flat enough though I'd guess they might be.
You said they were free so my advice would be to take one or two and try them out. Check them with a square and if they are flat enough, try it out. It certainly won't hurt.
ThomD
>If you had raw diamond dust, it might be fun to coat it with epoxy and dust over with diamond. Probably wouldn't last all that long, but then neither do some of the stones.
yes and...
David Miller from Iowa
>These would probably work well enough for most of us. However, a piece of plate glass set on the table saw is probably much flatter (and more abrasion resitant).
Gets back to one of my favorite themes - if you used this approach and got to the point where the granite properties were actually impeding your work, you would be way ahead of most of us.
David
Dave, how's your hand healing?
Tom Colligan
