Trouble with my LN BP
Neal in San Jose
>I've used my LN 60 1/2 plane for more years that I'd care to admit, without anything but praise for it's performance. However, yesterday after I honed the blade, I couldn't extend the blade far enough to make anything but fine, wispy shavings any more. The flange on the blade adjusting knob is running into the body, preventing it from going any further. I looked at my 60 1/2 R, which is almost identical, and the screw the adjustment knob runs on is a lot further from the body, so this will never be a problem on that plane. Has anyone else experience this? I sent an email to LN to see what they have to say, but thought I'd see if anyone here had a similar experience, and maybe educate me of my "user induced problem"!
TIA Neal
Re: Trouble with my LN BP
Joe Rogers, Northern Virginia
>Dismount blade. Unscrew adjuster. Remount blade with adjuster extended by engaging different notch in blade. Problem solved.
JR
Re: Trouble with my LN BP. Ditto
Joe Hurst-Wajszczuk
>Neal-
You're problem sounds a lot like like what happened to me a few weeks back while switching in a bunch of blades for an upcoming article.
Long story short: check the threaded rod.
In my case, the locking material holding the rod to the casting broke loose; turning the adjustment knob would simultaneously advance the blade (slightly) and back out the rod. It worked, sorta, but not as smoothly as it did a few hours earlier.
LN is a great company. I called, explained the problem, and they asked me to send the plane to them for inspection. Of course, they made things right.
Good luck,
Joe Hurst
Nope
Neal in San Jose
>Only one notch in blade. That would work in a Stanley with multiple notches, but no such luck.
And Nope
Neal in San Jose
>My threaded rod is tight. My theory, and it is only a theory, is that I have one of the first ones off the production line. Since this problem will only surface once the blade is sharpened many times and has lost some length, LN didn't realize there would be a problem for a while. Since the rod in my 60 1/2R is significantly higher, I'm guessing they changed the design.
Jack Guzman from Maine
>Neal,Contact LN. I'm sure they will fix you up. They have great customer service.---Jack
Been there, done that!
Neal in San Jose
>As I mentioned, I did drop LN an email; I just thought in the vast collective experience on this site, someone probably had run across this before and could set me straight. I'll post what I learn from LN.
This was sort of embarassing in a way. I teach a class in hand planes, and it was during the class that one of my students noticed the problem. After I had sharpened the blade to remove a nick that another student had put in the blade, I put the (newly sharpened and thus, shorter) blade back in the plane and got it to make a very nice, light shaving and put the student back to work. After a few minutes, he asked how to make it cut deeper, and it couldn't be done!
Just heard from LN
Neal in San Jose
>They say that they haven't had any reports of this problem. Maybe I'm the first person to use/sharpen it enough for this to happen! The have asked me to return the plane so they can see what I'm talking about. I will do that very soon, and report back here with further developments. Neal
Re: Just heard from LN
Scott Burr in Ben Lomond, CA
Guess I have a twitchie trigger finger tonight...
>Neil, All I can say here after reading everyone's posts that somethin' asray'.
Pull the whole thing apart reassemble. What i see, hear, read, is something is not right... This removes all unsuspected factors.
After the plane is assembled (hopefully correct 8^) check the mouth, that is if'in it's haz one. With my adj. mouth plane, it's always the last place I look...
