ADVERTISE HERE - FREE TRIAL
New tools in Berea
New tools in Berea
New tools in Berea
David Cockey
>Veritas has a very interesting display about how they design their tools complete with drawings and various development models. New tools include:
- Dovetail saw which will sell for $69.95. Back is a composite of polymer, steel powder and glass fibers, and is molded around the blade. Handgrip is wood which is attached to the back.
- Hand beader which is much more substantial than the wood one they have been selling. Looks like it uses the same blade.
Lie-Nielsen several several new tools including:
- Panel saw with a sign saying the first 50 will ship by Christmas, available with progressive pitch.
- Chamfering plane
- Tongue and groove plane
Re: New tools in Berea
Also LN chisels
David Cockey
>Lie-Nielsen also had several varieties of new chisels. Not sure which were prototypes, and which will be available soon.
ThomD
>"Hand beader which is much more substantial"
Well worded, but just in case someone thinks the wooden ones aren't up to the job, they have the usual rust-proof, warm in the hand, light and less likely to dent, advantages of wooden tools in general, ans work great.
Wooden beader
Alexander Grigoriev
>I didn't have much success with the LV wooden beader. Was I wrong to assume that when the bead is complete, the rod rides in the workpiece? With this setup, cutters always get clogged with shavings.
Re: Wooden beader
Bob Demers
>Alexander
I have lots of experience with that LV beader, and it work great.
By your sentence do you meant that you set the completed bead profile to be flush with the beam?
If so, you do not. Beads are never to deep, the cutter is plenty long to keep clearances between the beam and the finish profile.
The only issue I have with cloggings is when a part of the profile run under the fence block. Then depending on the wood species, I must stop once in a while to pick the stuff out of it, otherwise it interfere with the fence registration.
You see some wood are better suited to hand scratching than others, that is perhaps the biggest variable.
I also used to make my own with pieces of bandsaw blades, but I havent since I got that LV beader eons ago.
I really like the way the fence shape feel in my finger grip. Very slick design
Curious to see their new design...
Bob, up in snow country, home to LV. Looking at the pics comming out of Berea with frozen drools :->
