Anneal a wrench?
Anneal a wrench?
Anneal a wrench?
Tony - Memphis
>I have a 23mm wrench that I use in my shop that is a little too thick. I need to grind less than 1/8" off of it to make it fit in the space I need to get into. This is an open end cheapie wrench btw (chrome plated?). Anybody done this before? I've done other similar stuff before, but I thought I'd ask. I know Brian Boggs does this so he can adjust the wrench to be the exact dimension he needs for using it to measure gages for turning round tenons. I think I have the Woodworking in Action DVD where he mentions it. I'll check it at home this evening.
Thanks,
Tony
Re: Anneal a wrench?
Jack Guzman from Maine
>I have ground hand wrenches to do just what you are describing back in my other life as an auto mechanic.I never annealed anything.The wrench never got hot enough to lose the hardness.I just used a cheapo gray coarse wheel on a high speed grinder. If it gets alittle warm just cool it off in water and keep going. Those things aren't made of the same stuff as chisels.The steel is alot softer.---Jack
Tony - Memphis
>Thanks. I was sorta thinking along those lines. After I thought about it, I think Brian Boggs annealed so he could hammer one side of the wrench to make the dimension exact. I still have the wheels that came with my grinder, so I had thought I would use those. They remove metal in a hurry compared to the "good" wheels I use for tools. This thing doesn't need to be real hard for using in the shop. I failed to mention what I am doing with it. I got tired of using the collet lock on my Hitachi router. I measured and verified the dimesnion of an aftermarket wrench for the same purpose. I happened to be at Autozone the other day and saw a 23mm for $8.99. Good deal, but it is a little too thick. The aftermarket wrench is stamped and much thinner. It goes for $20 plus shipping.
Tony
Bill Tindall, E.TN
>I don't understand the anneal in the title, but anyway, I had to grind an expensive wrench thinner to replace the cheap, worthless wrench that fit the jib nuts on our old planer. Worked fine . I still have the wrench but not the planer.
concur
Bill Houghton, sunny in Sebastopol, CA
>The largest wrench I've modified that way (to remove the tie rods on my, now my son's, Volvo steering) is 1" - 25+ mm.
It does require patience, but it's mindless patience. I found flipping it over as one side got warm allowed me to stay at the wheel longer before dipping it in water.
Tom MacGregor
>I've used a 4 x 36 bench mounted belt sander with a coarse grit belt to thin down wrenches to fit tight spots. I toss on my welder's gloves & keep a bucket of water nearby. The wide flat surface makes it easier to grind the wrench nice & even. I've also made my own extra thin special-purpose wrenches out of plain ordinary 1/8" sheet steel with a bandsaw & a grinder.
Good idea
Tony - Memphis
>Thanks. Might be a neater job than what I could do on the grinder.
Tony
Re: Death nocking at your door
ThomD
>Do not heat a chromed wrench you run a risk from metal fumes. Heating galvanized is the classic, but avoiding all such fumes is best. Grinding it with an abrassive wheel would work. You could just add a shim to a larger wrench, and save the metric wrench for the coming metrification under the new administration.
I'm sorry Thom...
John in NM
>But I find your comparison laughable, chromium and zinc are so very different in properties that I think such a warning is very much un-warranted. If you can back it up with a referencible piece of clinical research I will happily eat my words (though no chromium).
Re: Appology accepted...
ThomD
>I didn't compare them I distinguished them and said I would prefer not to suffer either. Chrome is normally laid over Nickel also, so your list is incomplete. Both metal fumes are of concern and regarded as carcinogenic under current industry standards. It's tough to pull down specific information because most people would avoid such materials in the first place since processes like welding should not be attempted on chromed metals anyway. However, these materials are present in stainless metals. My alarmist title still only got 62 reads so I don't regret using it. Otherwise all I said was that fumes were a "risk", and "best avoided". If anything that understates current OSHA standards. Metal fume standards are widely regarded as being weak in current regulations, due to political considerations.
Christopher Fitch @ Memphis
>Do a search on google for OSHA Chromium Fumes. You will find plenty of info on this.
Some of the links focus on hexavalent chromium but there are other chromium references as well.
Annealing requires only moderate heating....
John in NM
>And chromium melts at very high temperatures. Granted melting is not the same as fuming, but I really think that such a serious warning about heating a chromed wrench to a few hundred degrees is psuedoscientific fear-mongering. Zinc on the other hand does melt and form fumes at very moderate temperatures. For what its worth I would not be terribly concerned by nickle either. Now if the discussion were about welding I would agree you might have a point.
Re: Annealing requires only moderate heating....
Todd O. Cronkhite Maine Native Presently Away
Dang John, kinda' strong language to use on a guy who was merely trying to pass along a potential safety hazard dom't cha' think.
Wear a mask!
Phil Joines in Krum, Tx
>Used a belt sander to sharpen an axe once. Was sick for 3 days from the dust.
Probably...
John in NM
>Kinda cranky working night shifts this week.
