How could this have been done with power tools?
Bill Houghton, sunny in Sebastopol, CA
>When our son did our garden fences and gates last Spring, we used a regular mortise lockset in the main gate, knowing that I'd have to adjust the gate a couple of times. With the rainy season here, the gate started to bind again. The first adjustment, a few months ago, was beveling the lockset side of the gate; this time, I had to remove material from the strike plate side (otherwise, I would have had to move the faceplates on the lockset side). Our son had glued and screwed an astragal on the strike plate side, which effectively made an 11/16" deep by 1-5/8" wide rabbet that I had to make 1/8" deeper, to give clearance between the two gate parts.
It's been years since I used the 10-1/2 that my uncle repaired for me, so it took me half an hour to sharpen it, but then I had a good time planing the gate, during which time, I was trying to figure out how it could have been done accurately with power tools. I guess I could have clamped on a fence to guide a circular saw or router; saw would have left a pretty rough surface, and I've learned over the years that removing even just 1/8" of material that wide is not easy with a router. Any other approach that I'm missing?
I'm not a purist - a lot of electrons have been sacrificed over the years on this house - but I remain convinced that hand tools give capabilities for certain operations that power tools can't touch.
Side comment: rabbet planes are sure good at telling you when your sharpening stones have gone hollow...
Re: How could this have been done with power tools?
Router
>Bill, it seems to me that this is a classic router operation, using a fence and a straight bit. The fence would keep you from running the entire length of the stile, but you'd only have to chisel the last few inches, or use a bullnose plane or chisel plane. The iffy part is the stability of the router base on the side of the garden fence or gatepost.
>Yes, it is really amazing what can be done with hand tools. All you need is about $3000 worth of planes, $1000 worth of saws, $2500 worth of drills and braces, a set of natural Japanese water stones at about $10000, $1200 worth of chisels, $800 worth of marking tools, etc. ad infinitum, and you are good to go. Oh, I forgot the part about learning how to use them. ;)
Oh, sweet!
James Watriss
>I'll go pick those things up on the way to the supermarket today. I have an ikea table that needs a repair.
true
>I was thinking of the router on the face of the door, with a long bit trimming the edge. But, if I'd matched a board to the astragal (that is, trimmed its edge so it was as straight or not straight [probably very straight - not to brag too much on my son, but he does better work than I ever will] as the astragal), clamped it to the face of the door with the edge level with the astragal, then run the fence against the board, I could have taken it down 1/8" without endangering the astragal, with good support for the router.
Describing it makes me as tired as I was when I finished planing the edge, though. And I had less dust in the air.
