#82 scraper
#82 scraper
#82 scraper
Kevin French, Antrim, NH------WebKitFormBoundary3x
>Other then the bay is there any place to buy blades for this?
Re: #82 scraper
Re: #82 scraper
Wiley Horne--So. Calif.
>Hi Kevin,
I think Ebay is about it, to find an exact vintage replacement.
However, if you're looking for blades to use, I have found that the No. 82 will work well with a wide variety of blades. Which is good, because sometimes you want a flexible blade, and other times (for roughing work), something thicker.
Don't know if you have one there in your hands, but for the benefit of those who may not.....the blade holding jaws are just under 2-1/2" wide, and the max. blade insertion is about 1-1/4" (this affects how long the blade can be). And the max. thickness blade that I can get into the tool mic's at 0.066" (1/16").
I have used (a) the stock blade, which came with mine, (b) shortish card scrapers, even though they hang out the ends of the jaws (in width), (c) paint scraper replacement blades (including the curved-end ones). I haven't done it myself, but am certain that old saw stock would make great blades, or if you're into hardening stuff, get some 1080 or 1095 stock from MSC, in whatever thickness suits you.
No. 82 is really a great tool! Does yours have the shock-absorbing spring?
Wiley
