finish rubbing out question
Bill Tindall, E.TN
>Well, the French footed Federal Wall cabinet is done except for final finish refinement. Wife says as coated shellac is too bright (I agree), and 4/0 wool and wax is too dull. Is there a route to something in between?
The mahogany is not filled so I presume I can not use some particle abrasive like rotten stone, which is about the sheen I would like to achieve.
Re: finish rubbing out question
My approach *LINK*
David Barnett - SW Florida
>My way: finish to bright, knock down, polish to desired sheen. On detailed carving/mouldings, highlight with restraint, leaving the recesses more matte for gentle contrast.
If your shellac was fresh and has cured hard, you might try lighly stroking to what I call 'high satin' with a slightly-worn 3M grey pad followed by Behlen's "Deluxing Compound". The friability of the grit allows control in acheiving the right amount of lustre and is forgiving inasmuch as it's undoable and redoable. This method (along with other variants) lets me produce the high lustre people often want without the greasy, sticky gloss of resins, whether shellac or amber, which I simply can't abide. Less rubbing will produce a softer glow (my preference). Just call me Mr. Matte.
Oh... rottenstone can make a real mess of any shellac that's softer, whether it was past its prime or simply too soon to have fully cured.
Behlen's Deluxing Compound
"RJ" Whelan
>Bill ... if you can try this in an inconspicous location (just in case it doesn't do what you want) this might work:
1. Soak a rag with shellac and lay it flat and let it cure for at least a day.
2. Lightly rub out with steel or bronze wool (0000)
3. Crumple up rag created in Step 1 and burnish surface
4. You may want to use a low sheen wax when you're done - I like Claphams (from Lee Valley).
Good luck ... rj
I have test pieces
Bill Tindall, E.TN
>I can try anything because on a new to me finish I always carry forward a large test surface to practice the next step on. I will try the procedures suggested.
Paul Kierstead
>As another option, continued rubbing with the steel wool (*without* changing it, flipping it, etc) ) will build shine, at least to some point. The wool gets duller (and probably choked slightly) and starts to leave a nice shine. Buffing hard with just a cotton rag can also bring up the shine without overdoing it.
Re: I have test pieces
"RJ" Whelan
>Bill ... let me know if this produces the desired results .. rj
problem solved
Bill Tindall, E.TN
>Mahogany Briwax plus rottenstone on a foam rub out pad. The gloss is between 4/0 wool and native shellac, just what I wanted. The rottenstone is gray and it did not change the color of the pores which I had already made dark with a dark glaze. I will 4/0 wool the cabinet frame and polish the crotch door panels and top to bring them up a notch in luster.
