Fretsaw blades?
Fretsaw blades?
Fretsaw blades?
>I use a fretsaws to remove the waste when cutting dovetails. I have a nice vintage jeweller's saw and one of the featherweight large fretsaws from Lee Valley (I really like this cheap saw for sawing waste on wide boards - extremely light and balanced).
An old picture ..
The problem I experience is that I am constantly breaking blades. This past weekend I was getting 1 1/2 dovetails per blade! I have Eclipse blades from the local borg as they are the only ones I know of. For reference, I use them on the pull and they are tensioned as tautly as I can get them.
Eventually I gave up and used my coping saw. It cuts very fast, but requires two cuts to the single from a fretsaw as it cannot fit the dovetail saw's kerf.
The question I have is whether others experience the same problem, and what blades you might recommend (and from where they are available)?
Incidentaly, is there a small bowsaw/blade that will slide down a kerf? Gramercy?
Re: Fretsaw blades?
Re: Fretsaw blades?
Warren in Lancaster, PA
>I use a coping saw for waste removal. I don't think it quite fits in the kerf-maybe I hit the kerf running and saw a little as I go down. If you use a fretsaw with a more delicate blade you have to be more gentle with the saw. I would try for a smooth and deliberate action. It may seem odd to go slowly learning a technique that is designed to save time. Also if there is plenty of tension things go more smoothly.
I got a coping saw for Christmas in 1958 and broke the blade in the first minute of use. But last week I used a fretsaw to cut out some complicated foliage appliques in walnut without even thinking that the blade might break. Light at the end of the tunnel.
Re: Fretsaw blades?
Re: Fretsaw blades?
Dan Donaldson
>I use scrollsaw blades. You can get them in many configurations and tooth counts. Work fine in my frame.
Re: Fretsaw blades?
Re: Fretsaw blades?
>Hi Warren
Thanks. I echo your experiences with a coping saw. Mine cuts fast with excellent control. The speed makes up for the extra sawing over the fret saw.
I should have been clearer that the problem I am experiencing with the fret saw blades snapping has only been since using Eclipse blades. I had a different brand before, a box of "no-name", that I had bought several years ago, and these subsequently ran out. (They, too, did snap eventually, but would last a fairly long time). They are no longer sold by the store. The Eclipse blades are also not coarse enough and cut very slowly. So I am looking for recommendations for better blades.
Re: Fretsaw blades?
Try wax paper...
>you know the stuff on a roll in the kitchen. Place if over your work and it will lubricate the cut and cut down on broken blades.
Stephen
Re: Fretsaw blades?
Eclipse blades
>Derek, I forgot to mention it earlier, but I have been using Eclipse blades also. On Friday I sawed walnut for about 90 minutes straight; my hand got tired, but the blade (16 teeth) is still in one piece.
Re: Fretsaw blades?
Re: Fretsaw blades?
Alex Grigoriev
>Here, in USA, the Orange Borg is selling Buck Bros branded blades. They last pretty long.
Re: Fretsaw blades?
Re: Fretsaw blades?
Dale Warder
>Derek,
I use a fretsaw for cutting dovetails and fretwork. Usually, I use scrollsaw blades made for power scrollsaws, Shark No. 5 skip tooth. For finer fretwork, I use jewelers blades, Hercules No. 2 thru No. 8. The scrollsaw blades are available from one of the scrollsaw suppliers, I can't remember exactly who. The jewelers blades come from Rio Grande. I'm sure that you would have similar suppliers in OZ. While I do break blades, they last a reasonable time. Also, I use short broken blades in my saw frame until too short for the job.
Dale
Re: Fretsaw blades?
Re: Fretsaw blades?
Alan DuBoff
>Derek,
I have had mixed results with the fret saw, and I have broken a good many blades and especially on hickory and purple heart. Hard maple is not as bad, but I still was breaking more blades than I liked.
Joel has coping saw blades in .018", and they give you the best of both worlds. They give you a blade that is thin enough to fit between most all dovetail kerfs, and they allow you to turn the blade in the handle so you don't have to bend the blades on the end so you can get the fret saw turned enough sideways to position it correctly to cut the waste out.
Since getting those .018" coping saw blades from Joel, I'm not sure I have used my fret saw since. All of our mileage varies.
Regards,
Alan
Re: Fretsaw blades?
Re: Eclipse blades
>Hi Warren
I think that what you say emphasizes that I need to work on technique. I am not sure what I am doing differently to before, but the Eclipse blades - while not the best to use - are unlikely to be the cause of the snapping, or as much the cause, as I previously thought.
Vallorbe blades come highly recommended by jewellers, and I have discovered (via the internet) that a supplier has an agency 10 minutes away. I think I will have a look there as I would like coarser blades than I have. I suspect that part of the reason for snapping blades is my overenthusiasm with blades that have too many teeth and cut so slowly. My old blades cut much faster.
Thanks again.
Re: Fretsaw blades?
Oh Derek.. Don't you remember my poen...
Scott Burr in Ben Lomond, CA
>About 2 years ago? You want a coping saw (wow saw is was backwards) Pins hold the blade and you can twist them to a point.
