OT (but still tools) What is this stuff?
David Miller from Iowa
>This came in a box lot at an estate auction that belonged to a dentist and heavy duty amateur machinist (i.e., there were both dental and machining stuff in the box).
It is a sheet of some odd kind of plastic 1" thick. It is both stiff and soft - you easily can make a fingernail mark in it but it goes away. It shows several episodes of sawing as if peices of different sizes and shapes have been sawed off at different times (at least with different saws).
Any ideas?
Re: OT (but still tools) What is this stuff?
ThomD
>Looks like a urethane rubber. Not sure if there is an dentistry application. I know they use/used liquid latex.
Patrick Gibbons, Katy, TX
>Hard rubber would be my first choice but you can tell fairly easily. Does it have a distinctive odor?
Jim in Burlington Ont.
Phenolic resin
>Looks alot like phenolic resin to me. Bizzare stuff it's used in sheets like that in Bowling alleys. Rubbery plastic and it absorbs energy. Nice to have it you need to hammer something a bit and not scratch the show side.
Probably not ..
>Jim, it does not sound like phenolic resin. That is used in the computer industry for circuit boards, and it is stiff and hard (being essentially fibreglass, as I understand).
Sounds like a very stiff form of sorbothane...?
Dave Anderson NH
>Given the description of a fingernail indenting, I agree with ThomD's choice. Depending on who you ask, urethane is either a plastic or a rubber though in both cases it is a thermoset material. Really useful stuff as it is extremely abrasion resistant and is non marking.
Self healing
>There's alot of different kinds of Phenolic Resin out there. Most bowling lanes of the 90's were made from phenolic resin instead of Hard Maple. It is flexible and has some self healing properties. It absorbs the impact of a bowling ball. You can machine it with woodworking tools. It has a very acrid smell when you cut it with power tools.
