Butcher block flattened... One more Q
Denis Ch�nard, Orl�ans, Ont.
>I finally got around to flatten my butcher block top yesterday. I used a router and a sled, and after spending an hour setting up, checking, re-checking everything (tailed tools have this nasty habit of not stopping when you want to if things slip), I finally went at it. It worked well, but the surface was left fairly rough (I used a 1" straight bit). Then on to sanding. And sanding. And sanding... The coarsest paper that I had was 80 grit, and it took like an hour to remove the milling marks from half of the top (which is 24 x 21"). Now I had to sand because hand planing does a number on my hernias, but after an hour of sanding I had it, so I took a plane out to at least remove most of the milling marks and then finish with the sander. Made things go a lot faster, and my hernias didn't complain too much...
Now for the question... There are a few areas that need filling. One joint less than tight (although it looked OK before milling), and a couple pieces of wood ended having small voids in the grain, which weren't visible before milling. Since I used Titebond III for the glue-up, I thought of making a paste with sawdust and the glue to fill the voids. Do you think it'll work (i.e. last), given the use a butcher block is intended for? Any other suggestions?
If that makes a difference, I plan on finishing the top with mineral oil.
TIA,
DC
Re: Butcher block flattened... One more Q
Richard Jones
>I think I would fill any voids with epoxy.
R
defect filling
Bill Tindall, E.TN
>Make wedges or points, apply glue and drive them in and chisel off what sticks out. . The repair may turn out invisible.
Re: defect filling
ThomD
>With cracks in joints that aren't tight, you have two problems, one structural and the other aesthetic. I drip hot stuff, or other very thin CA, into the joint and immediately sand with fine paper across the joint this will make the joint invisible. I should say that if the cracks are deep you may need to do a few shots of glue until they fill, could be a lot. Don't sand across the surface until they fill. You can work up to the edges of the cracks with shelac first if you want to prottect the wood surface from a glaze of CA. This is a pretty simple technique but a variety of things can happen, none too terrible, that have to do with the rate and colour the CA sets up at. Normally with Hot Stuff it is pretty easy to get the hang of, but you might want to try it on the underside firts.
Of dings etc... it is hard to fill them perfectly. I normally use epoxy if the surface is structural. A good gade of 5 minute is fine. Put some sawdust in the osterizer and reduce it to wood flour. Mix with epoxy, but don't let it get too dry, then insert with tootpick and later level with cutting tools and sandpaper. I also use raw epoxy without colour, or occasionally mix in a contrast colour. Black gets lost in the pitch marks in cherry. Or Red. Colouring earth pigments are good too.
It is harder to hide marks in maple, but this isn't the kind of project were I would be anxious to try a faux process.
